Starting Ranger with FordPass in cold weather
Igor
Igor
Ontario (ON)
Ford Ranger 2020 XLT 4x4 Sport
Does anyone else have issues starting Ranger remotely with FordPass in cold weather?
DHare
Missouri
What do you mean by "issues"?
SILK
Ty
Eastern Pennsylvania
2019 XLT Crew Cab Sport, 2018 Santa Cruz Tallboy
IT Director
Yesterday morning, it was probably 31 degrees and the command didn't send. Yesterday afternoon leaving work it was ~40 and it worked. This morning it was 25 and it worked fine. It's never not worked for me. I'm not sure if yesterday was an oddball or if you could be onto something. FWIW, I'm on iPhone XR w/ iOS 14.2 and the truck has Sync 3.4.20136.
slowmachine
New Hampshire
Mine failed today. I was standing about 100 feet from the truck, so it seems unlikely to be a connectivity problem. 20F outside temp.
THLONE
Thom
Tucson,AZ
internet wise guy
That is about what you can expect from Ford pass. It is operated by a high school class in Detroit. Did you know that when connected to Ford Pass, Ford is monitoring your driving habits. ?
Living The Dream
The truck uses an AT&T cellular connection to the FordPass app so if AT&T reception is spotty in an area, FordPass will also be spotty.
If I park my truck in a certain part of my driveway the FordPass app won't work.
Igor
Igor
Igor
Ontario (ON)
I wonder what they use in Canada? Hopefully not some crappy provider.
VAMike
2019 Ranger Lariat SuperCab
It doesn't matter where you stand. The command goes from your phone through your network, across the internet, to a server a Ford, then another command goes from the server at Ford through some series of networks to at&t, then via cellular to the truck. (This is why I don't count the app as a backup mechanism for opening the truck.)
JoeC
New England
I had trouble with mine this morning too.
It said something like 'try again later'.
I don't think it had anything to do with it being cold (25).
I think the Ford server was on the fritz.....AGAIN.
Just my opinion, and experience with the APP.
kastory
Keith
Findlay, Ohio
2020 Ranger Lariat
I had problems on Monday and contacted support. There was an issue with the app of the backend server. They said it was partially working until last night and it is supposedly fixed. Now the issue is that some are reporting excessive battery drain on the phone from the app. I think there maybe a new version of the app or coming soon to fix.
bearrug
Idaho
2021 Ranger STX 4X4, 2023 ford Bronco Sport
Mine also didn't work this morning ,also didn't work on my wife's escape.
Traneman
Jay
Rochester MN
2019 Ford Ranger STX 4x4
Used it a few times last winter, and I did it last night to make sure it still worked after my iOS update. Never had any issues.
