Start-X Remote Start Kit. Installed, Works Great!
lazynorse
Washington State
Ford Ranger Crew Cab XLT FX4
Public Health
I work from home and my truck often sits for a few days, long enough to enter a battery saver mode. This disables remote start via the Ford App, frustrating when it’s freezing outside and I can’t warm up the truck.
Researched and settled on this.
Start-X Remote Starter Kit for... https://www.amazon.com/dp/B07F422Y98?ref=ppx_pop_mob_ap_share
Watched a couple YT vids and installed. It goes inline behind your code reader port. Trickiest part is manipulating the tightly cramped plug from behind the reader/lower dash. You will be twisted and grunting. After a relatively simple and well explained sequence to program (hold a button, wait for a light sequence, plug in) its done. My mistake, I kept holding the button through a sequence of 3 lights, was supposed to let go when it cycles into a blue light.. thought it would stay on blue. I misread. I found a convenient spot on the metal behind the clipped/flip down plastic (to access fuse panel) to ziptie. Multiple zipties included.
On keyfob, press lock>unlock>lock. Truck remote starts in about 5 seconds. Repeat the sequence to turn off, step on brake, or apparently after 15 minutes it’ll shut down. Just like the App, it requires a key turn to drive.
Looks like its often $120, I got it for $100. Worth it! This model works on many Fords, including our 5th gen Rangers.
ScarzRanger21(2.0)
Eric
Auberry, CA
2021 Ranger 4x4, 2019 Ranger Fx4
Electrician
I was thinking about putting one of these on the wife’s truck. Hers is a 2019 xl so it doesn’t have remote start. Glad to see it functions well, I might pull the trigger on it…
I also agree with the previous comment. If your truck is going into battery saver mode after a few days, you might have an issue. My truck has sat for weeks and I never got the battery saver notification.
I learned about StartX when I got my 2019 Ranger. When I got my 2012 Frontier it was the first modification I did. I can say that it's a fantastic modification! Certainly well worth the cost!
highway
steve
kentucky
2020 ford ranger xlt
I had start x on my last Ram and it worked great
lazynorse
lazynorse
Washington State
Public Health
Shouldn't be in battery saver after just a few days unless you have a draw or bad battery 🤔, mine has sat for weeks and still been 👍...
Yeah, I’m baffled. Asked the dealer to look at it during my last oil change. While they said they don’t do deep dive diagnostics in the ‘quick lane’ for oil changes, they did test the battery and it measured better than minimum standard of healthy battery. I bought it new Sept 2022, only have 20k miles on it. Just today, I got the battery safe mode alert on the app immediately after a 20 min drive. Sometimes I wonder if the app is to blame. Guess I need to pay for a diagnostic, which sucks.
NotBudule2
Robert
21 Ranger
A new battery is probably cheaper than diagnostics from the dealer, and that's most likely what it is...
skrumpe
Scott
Georgia, USA
2019 Ranger XLT
Parts Sales Manager
Does the app not work with XL trim? I have an XLT so I have to use the app for remote starts but I don’t know anything about the XL
Correct the app does not work with the XL/STX due to the modules(or lack there of) on the vehicle
