Spray bed liner - with or w/o ?
jubreunig
Juergen
Tuscaloosa AL
What do you did with your bed rubber grommets? Over sprayed or removed?
For what are this 2 big ones at the cabin side?
What do you recommended?
Lmood
Adam
Savannah, Ga
My little grommets were removed and the two big ones were sprayed over by linex. Not really sure what those are there for. There are pressure flaps on the cab in that area. Maybe to do something with that?
Sandman Ranger
Pete
Lead Process Engineer
Use large grommets for drain line hoses on Bakflip top.
FULLSCALE
Adam
Ontario, Canada
I took everything out that I possibly could. The ones at the front toward the cab are easy to remove, I used a yard stick down between the cab and bed to release the clip/tab holding them in.
HenryMac
Mech. Engineer - Retired
Pictures make it real..... what exactly are you referring to?
My Ford Factory SuperCab ToughBed shown below
jubreunig
jubreunig
Juergen
Tuscaloosa AL
perfect picture... it seems that your small grommets are w/o and the bigger one are sprayed. That' s what I wanted to know - thx
PatrickM
Patrick
Sin City
www.pmiyoshiphoto.com
Subaru Outback16, Ford Ranger 11
⭐ tender
I sprayed on the UPOL raptor liner, took all the rubber grommets, screws on tailgate and metal tie downs. Makes it look more like a professional install.
Lmood
Adam
Savannah, Ga
That looks great @PatrickM ! Had I not negotiated my spray in liner when I bought the truck, I would have gone this route. How was the process in your opinion? Looks like a pretty straight forward process.
PatrickM
Patrick
Sin City
⭐ tender
9A moment ago
NewPretty simple, a 1/2 days work of prepping (sanding, vacuming, cleaning and taping off). The spray gun supplied isn’t the best thing in the world but effective. My air compressor wasn’t working all that well so a little bit of a problem towards the end trying to keep a consistent PSI, but all in all, I’m quite happy with the outcome.
Do you have a link to the kit you used?
jlmotox
CA
I used the U-POL Raptor liner also, Great stuff! Completely happy with mine! Got mine on amazon, 4qts and a spray gun for about $120 if I remember right.
PatrickM
Patrick
Sin City
⭐ tender
Yes, that’s correct on price! Did you end up
Using all 4?? It seemed like I only utilized 3 quarts??? 4 seemed like over kill but I guess if you have a thicker coating I’m assuming better protection! I did more thicker coating on the sides, front and tailgate and less on the floor, since I’ll be adding the decked system.
jlmotox
CA
I used all 4, it’s on there pretty thick.
