SOLVED: Engine Shroud Cover Missing On XL and XLT Trims?
FULLSCALE
Adam
Ontario, Canada
Do you have a picture of the cover? Just curious to see it, the only pictures I've seen show the engine without any cover.
DHare
Missouri
Bubbabiker
Ford F150 Supercrew FX4
Thanks for the pictures. Without the cover I see several bosses that are used for mounting the cover. So it can be added later.
JoshE
Joshua
Harrisburg, PA
2016 Tacoma
Just read the engine shroud (beauty cover) will only come on the Lariats. XLT and below models will be naked. True?
If so are the mounts still present so the shroud can be added later?
This is true and I can confirm the mounting points are still present. I test drive an xlt last night.
Toytec
Central NC
My thinking is that the cover has sound insulation under it and makes the Lariat models a little more quiet coming from the engine compartment.
Those direct injection pumps really clackety clack.
Defender
Altoona, Iowa
2010 Mazda6
If the XLT comes without the shroud, I wonder if it can be purchased direct from a dealer and installed. Anyone familiar with the idea?
Ranger207
Maine
2006 Toyota Tacoma
I went for a test drive in a Lariat yesterday and took a closer look at the cover/shroud. It appears to be made entirely of a high density foam, and apparently its purpose is to deaden the sound from the fuel injection system. It's too bad that Ford doesn't include it on all Ranger models.
Bubbabiker
It's Ford just being cheap. For 2019 Ford removed the F150 2.7L engine shrouds on the XL/XLT's too.
