Show me your leveled trucks on OEM wheels!
RANGER_MARC
MARC
Delaware USA
FORD RANGER LARIAT 2019
TEACH
Looks really good Marc. How do you like the ride with the Fox kit? I really liked the way the RC kit raised and stiffened the front end up on mine.
Hey, Dave, yeah, I really like the ride with the Foxes, definitely more stable to drive, and I am loving the higher vantage point as well!
rooster
BOS
STX FX4 SuperCrew
nerd
Did it firm up your front end a bit as far as ride? Are you an inch higher in the rear now?
I think it does feel better out front, including the steering which to me seemed notchy at low speed with the stock suspension/rake. I was just out cruising the local highways at 75-85 mph and it was nice and stable with as good as handling as you can expect from such a truck. On my Jeep the coil spacer budget boost seemed to give more room for tire but worse road manners. So I'm really liking these preload collars on the Ranger.
The rear stays the same, when lifting the front you are rotating the truck around the rear axle. In fact, tailgate load height dropped an inch an I believe.
One thing I'll say is the spring compression was a tough using DIY hook style compressors. I've used these with ease on my VWs but not here.... there is not alot of clearance between the ID of the spring and the boot/bump stop, it took a few times to get just enough compression with everything staying centered and not binding up. And with the preload collar in place they really need to be cranked down to be able to catch the first few threads to get the nut on. You will be at the point you think it's all going to explode in your face. If you have access to a shop compressor like a Branick or a local shop that can handle the springs I recommend going that route.
Aside from that, if the inner cv joint pulls out don't panic ... a little finesse with the rotating and shaking will get it back in.
Now, onto that bouncy rear end...
John Jenkins
Pennsylvania
19 Ranger Larait 4x4 Super Cab
I feel as if I’m a bit stiffer in the front but still a nice ride. Right now my truck sits a 1/2” higher in the rear. And I could have run next size up in tires(33”) with no issues
Arch Stanton
Reno Nevada
2019 Ford Ranger XLT FX4 4x4 Ingot Silver 301A
V.P. of Research and Development; Telemetry and Guidance Testing Facility at Aerodytech Corporation, Reno, Nevada
Thanks for the review. By front and rear measurements I was referring to wheel well centerline to ground, usually about 3" higher in rear from factory, so assuming your are 1" higher in back now.
rooster
BOS
STX FX4 SuperCrew
nerd
whoops sorry, I confuse easily! Yes now 1" higher in the rear ... front fender to ground will be in the range of 37" and the rear will be around 38".
Arch Stanton
Reno Nevada
Thanks, torn between the Eibach shocks at 2.25" and these 2"collars for $100 less.
rooster
BOS
STX FX4 SuperCrew
nerd
I just did the rear Eibachs this morning, signficant improvement overall, much more solid feel in the rear. If the fronts are just a good I might go that route eventually.
Lost19Ranger
2019 Ford Ranger XLT FX4 PKG
Sales
Ok guys I see a lot of 2.5” and a lot of 3” levels. What space do I need to go with? I just want my truck level lol. I don’t want my rear to squat but I’d like it level lol. Any advice would be appreciated
FULLSCALE
Adam
Ontario, Canada
3” if you want it level with the back. I went with the 2.25” Eibach setting to keep a little rake.
Lost19Ranger
Sales
Thanks for the quick response, I’m still debating when I’m going to level the truck as I don’t want to buy a new set of tires lol
Just keep in mind that with the 3" level if you ever tow or haul heavy stuff in the bed now the front end will be higher. I went with the 2.5" level and it's only 3/8" lower than the rear,it still looks perfectly level by eyeing it.
I never intended to buy new tires either but if you're on here long enough you'll end up with them. lol I went with the 265/70/17 because there's no rubbing and you don't have to cut the crash bars.
Lost19Ranger
Sales
Oh I know I’ll end up getting new tires but as of now I wasn’t to wear out the stocks lol. I Thinking of the 2.5 you both make a great point
James Martincic
Jimmy
Pittsburgh pa
2019 ranger xlt, 2005 Saleen mustang, 2019 ram 2500
3” lift before and after lager tires on stock wheels
