- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,653
- Reaction score
- 8,916
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
I would check the rotors and ensure one is not slightly cocked sideways on the hub and or warped.Hi Tim, I did get a 4 wheel alignment when I changed out the front and rear shocks (back in 2021). I did not get a 4 wheel alignment after changing out the leaf packs that I did in March. The truck was running fine up until I took it in to DT to have them put the other set of wheels/tires on.
As this is the only thing that comes to mind, started just after wheel / tire swap and placed old back on - and still present
I am sure if you were to jack it and spin the tire, you would possibly see a side-to-side wobble of the tire as the wheel is not setting truly flush on the hub be it cocked rotor, or the rotor hub surface is warped.
