Driveshaft install gone wrong
tgross2
Tyler
Wyoming
2020 ranger
Hi all!
I was replacing my driveshaft when on the differential side, one bolt broke, I proceeded to torch and PB blast for hours to no avail. I eventually tried an extractor, and broke one off in the bolt (it looks like someone has had it off before, and cross threaded it home). I am now at my wits end with this. What is my option? can I replace the companion flange? if so, how is the job? it looks like it is one singular nut, but I am worried about the torque, as I know they are sensitive.
OGMix376
Bryan
I don’t know if this is a feasible option.. but drill it out, re thread, and use a slightly larger bolt?… thinking about it though it might cause a imbalance from the slight weight difference..(that could be splitting hairs though.)…
Maybe have a shop do it?
like you I would feel slightly uncomfortable replacing.. and take it to a good shop. (Specialty shop if I could find one.)
Hope you get it sorted out.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
You can swap the flange, but it technically requires removing the differential cover. And the carrier because there is a torque test for rotating resistance.
However there are online write ups on how to do it the back yard mechanic way.
Fawnbuster
Indiana
Retired 34 years as LEO
If you drill it out can you put a helicoil in it or is that too much torque, I have only had one out into a lawnmower for a sparkplug.
Retap it, helicoil and use the oem size bolt?
