Second Spare Wheel?
Blmpkn
Maine
2010 ranger
As happens many times, just read this thread. Bit late but that's the story of my life. Learned something too...... learned that it still sucks not having D Fresh around here.
At least all evidence of his existence here wasn't erased like somebody else ? lol
thorn726
thorn
Berkeley CA
2019 Ranger xl
Are you going to buy a 5th rim of your type? if not and if it doesnt matter, i can't say about mounting but to buy the rim go to EBAY! they have "take off" rims for $60. I am in a 2wd but i do a lot of long distance on dirt roads with sharp rocks so i sometimes carry a second spare just in case and found that we can get rims pretty easily/ the trucks are mostly shipped with the stock rims so when someone upgrades they take them off and the old ones go to a warehouse.. these are just the 16 inch cheapo rims that come with an xl like mine but if it is just for an emergency spare it might work depending on how big your wheels and tires are....
sand mode is 4 high so you can use it to go faster than first or second gear speed. i never been faster than 3rd gear in sand mode and off road that feels stupid fast to me. im not sure exactly what it does but yes the throttle input is much more direct in sand mode than the other modes. you mentioned mud, we have a mud and rutted mud mode also. it works really well. ive used mud mode to get past stuff i was certain id be winching out of.
Seventeen_days
Seventeen_days
Dillon
Utah
2021 Ford Ranger Tremor
Does anyone have an image of where the AdvanceTrak button is located?
Question regarding Sand Mode. I've only tried it once, but doesn't it change the way the vehicle accelerates - I recall it became very peppy on acceleration. Also, can Sand mode be used at higher speeds? If I recall, it felt like Sand mode was limited to lower speed so I stopped using it. I drive at higher lake bed speeds and just want 4WD.
As for RSC (roll stability control), I've run into this often and it basically shuts everything down. This creates a new issue when driving at speed - i.e. not good!
There is no separate button for the AdvanceTrak. If you hold down the traction control button for 5 seconds (maybe 10 seconds), you get a pop up on the dash saying the AdvanceTrak is off.
I am not a fan of the RSC
Seventeen_days
Seventeen_days
Dillon
Utah
I found a good deal on a used set of tremor rims and tires so I picked those up and replaced the non-matching spare and have one to put in the bed.
Now I have 2 tremor spares and 2 steel spare rims and tires that I need to get rid of haha
lariat
Western US
Ranger Lariat
student
I went in Sand mode, traction control off and 4H today and liked it a lot. Vid attached
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
I just turn off traction control when driving in sand, and feel with my right foot.
The terrain modes and 4WD will definitely help with you not spinning tires on the trail. As for extra weight in the rear? Well I won't argue it can help in general for some situations. I also recommend going a little lower on the tire pressure. Even going towards 20 would help in some situations.
As for the second spare, honestly tire technology has come a long way over the years(that said some tires are still junk). Unless you are going to a place that is so remote and there is no one near for days and you are alone I don't see a reason to have a second spare with the vehicle.
It's your call from there
thorn726
thorn
Berkeley CA
2019 Ranger xl
For most places a second spare is overkill BUT: any of us who go thru Death Valley back roads or similar desert like AZ will tell you a second spare is nearly essential. Some of these roads are famous for having sharp rocks that slice up tires. Ive been fortunate and it only happened to me once but wow if you hit one wrong/ even going 10 mph they just slice you right up. Multiple flats are fairly regular on some of these roads. I find that keeping it to 20mph or less is a huge help but a lot of 4x4 people want to go faster and they run more risk of being sliced up. /and we're 30-60 miles from pavement and even farther from a shop in these cases so yeah// while somewhat rare, there are some situations where a second spare is very good to have.
And the same individuals don't air down either. That does not help OffRoad at all
thorn726
thorn
Berkeley CA
2019 Ranger xl
50/50.. i think these days most of the off roaders i see have on board compressors/ but once they air down they tend to go even faster, negating most of the safety benefit of airing down// but to your point yes, not airing down will definitely increase the chances of getting a flat from a sharp rock. I think the flat i got was before i had a compressor even though i was going really slow... Anyway when getting a flat far from pavement, having an extra spare is very comforting.
folks may make fun of me but i carry 3 spares sometimes. but 99% of the time im alone. and dont have any friends or relatives in my area any more or the places i go off road. its common for me to have the cell phone not get signal as well. so if i know im going to the some place sketchy i bring a lot of stuff along. some tools, extra food water and clothes etc.
20XLRangerFraptor
Clifford
Waddell, AZ
2020 Ranger XL
Jet Mechanic
Anytime I'm going offroad traction control off, then advance trac off. I'm normally in sport mode with me shifting the gears in manual mode. I don't usual mess with the terrain managment because the all want to be in 4wd. I stay in 2wd until I actual need 4wd. I slide and drift corners very easily and sometimes the roll stability will kick in which makes me mad! Normally it only kicks in if I'm really hammering down running like 50+mph and taking turns and sliding alot. But with "normal" trails/dirt roads I can slide and drift the turns without it kicking in.
