- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,468
- Reaction score
- 8,544
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
It is my understanding of the system can learn the new SOC, (The rest period- untouched)this is the same as placing the battery on a charger but however the charging algorithm will still be set to the old battery, I am determining this by - resetting the BMS - resets the time since installed date ,which in turn also forces a SOC recalibration. ( Programed Data-new battery)This is what I have read. And below is what Ford states in their manual......
If the reset is not carried out [using a scan tool] it takes approximately 8 hours for the BCM to learn the new battery state of charge. During this 8 hour period, the vehicle must be undisturbed, with no doors opened orkeyless entry button presses. If the vehicle is used before the BCM is allowed to learn the new battery state of charge, engine off load shedding can still occur and a message may be displayed.
The BMS reset is the only way the BCM is told (knows) a new battery has been installed, or a (self force reset) to possibly fix charging (battery) issues and still using the old battery.
To clarify, a BMS reset will show in PID data for the Battery- Time since installed (current date) on when you did the reset.
The charging algorithm will adjust to a new battery and charge accordingly (this algorithm ties into the Battery IR) as it ages the IR increases, and with the help of the desulphator , this keeps the IR in the low range.
