Removing Dealer Stickers?
JACKSMYDOG
Jay
Ontario
2020 Ranger Lariat FX4 Black
Dental floss or fishing line, followed by Off, Goo Gone or Isopropyl alcoh
Ho-ho-hold it right there for a second Marc!
Did you say “the Duke of Dampers”?
Just so there’s no confusion out there, when it comes to Dampers, there’s definitely no Duke. ?
What's the dental floss for? I've seen this mentioned in the keypad removal threads too. Dragging anything under a decal near your paint just sounds like an accident waiting to happen. Any little grit gets trapped, yikes.
I worked in a body shop for sometime as the dummy, and peeled lots of deal and hard decals (like the silver eco-boost on the tailgate). Fingernail or trim tool under the edge, and slow even pressure they come right off.
GOO GONE is my go to glue remover.
Here
XLT
Dental Floss - for removing badges - loop it behind, work it along the back.
RANGER_MARC
MARC
Delaware USA
FORD RANGER LARIAT 2019
TEACH
As a compromise, I wonder if Dave would accept to be dubbed the "Dean of Dampers"?
Bob902
St. Louis
RETIRED!!!!
I can't stand the decals. i remove them and their plate frames first thing when I get home.
JACKSMYDOG
Jay
Ontario
Okay, but why? Thumb nail or trim tool under edge, pull even slow pressure. What does the dental floss do, other than increase the chance of damage?
The dental floss has a coating on it so there's less chance of damage from prying with a trim tool.... ie user error. :wink: Most of the time doing it this way you can get all the adhesive off in one shot. If I do it this way I'll usually add a little spray wax to it so it slides easier.
Danager
Dan
Alberta
2019 Edge
Manager
I believe you only use the dental floss on badges and things held on with a foam tape. Easy to tell if it is foam tape by pressing on it or twisting it. If it moves, use the floss. The floss cuts the foam easily and you are left to remove the adhesive after. This is tricky on some larger badges. The F-series badges are so large, they curve AND have clips and alignment tabs. The floss hits the body. Fortunately, the wax from the floss cleans up easily.
I would not use this for a decal/sticker though.
After I remove whatever I’m working on, I always hit the adhesive residue with NuFinish polish. It breaks things up quite nicely.
I took delivery of my truck a week ago. 4 days in and I removed the dealer sticker, Tremor stickers, and the keypad from the door. The keypad was the worst to remove but all areas cleaned up easily.
JACKSMYDOG
Jay
Ontario
I suggest there is zero chance of damage from lifting at the edge (not prying) whereas forcing any material between the paint and badge, adds a layer of potential damage not present with my method.
Mustang2Ranger
Garrett
Southern California
Here you go
Paint safe
Leave it in the sun and peel it off and then use this for any leftover residue
Here
XLT
A service advisor once used a screwdriver to remove a dealer badge from my Mazda MX-6. It didn’t go well - not for my trunk lid and not for him.
JACKSMYDOG
Jay
Ontario
Moros are going to moron. If you had given him floss, he probably would have scratched it with his pinky ring ;)
