  • Total voters
    395
Fitzmotor
Gold Sponsor
Saugus
Retired from Honda Racing.
Voted yes many moons ago. Please put me on the list.
You are, I'm as anxious as you are, just waiting on hose, I have everything else, once that shows, I can fill a lot of orders.
I feel like this a joke product, but I'm never really sure.
It's legitimate.....just went to my local Harbor Freight web site, and that 10mm set is pictured, real, and $14.99
Going by there today....I'll take a pic. May even buy one for Sh-ts n Giggles.....
Stevedbvik1
2022 Ranger Tremor XLT
Get the ones with the Bluetooth tracking chips
2021Ranger
Barry
NJ
2021 Ranger
Just buy 2 of them so you have an extra when it rolls under the truck or when you drop one under the hood to never be found again..
I'm picking one up...not to use...for my display cabinet...
Essthreetee
2019 Ford Ranger XLT Sport 4x4 Super Crew
HS Teacher
Just sharing. I finally got around to installing my Fitzstick and it is amazing. The build quality, packing, and shipping is top notch. The install is simple, I had my wife pushing the tube down from the top while I guided it from underneath. Fit and finish is perfect.
Thanks again for building something (better than Ford would have) that should have been there the whole time.
Ranger_Rocks
Wandering
Wanderer
FitzStick 069 installed !!
As many have commented, accessing and removing the OEM cap was a challenge. We have the FP/Fox leveling kit which provided enough clearance to work underneath laying on my low profile creeper. I was unable to break the OEM cap loose. Not enough room to comfortably swing a hammer attempting to hit a wrench on the OEM cap.
To go in from the top, I would need to buy long extensions that would likely never be used again.
I turned the wheels full left, removed the liner, then easily removed the OEM cap with a 12" long 3/8 inch drive flex handle breaker bar, 3/4" deep well socket, and 24 inch section of 1/2" steel pipe for reach. My tool collection does not contain a 19mm deep well socket. I used 3/4" deep well. NOTE: 3/4" = 19.05mm
This method provided the best torque angle with plenty of clearance for swinging the bar to the right and easily removing the OEM cap.
Initial cold level: (FitzStick initial cold level measured nearly the same)
For more wire bundle clearance, I did remove the light colored christmas tree fastener below the stick, pushed the harness below the metal attachment tab, then secured with a plastic tie.
Plenty of distance from the A/C tubing.
Thanks Mike for your attention to detail, craftsmanship, and making the FitzStick available for others.
Truly a much BETTER idea !!
redone17
Cold Spring, NY
2021 Bronco Black Diamond, 2020 Ford Ranger Lariat
Wheel well looks like the best method. I hope to tackle this tomorrow. PPE Pan + Filter in the following week or so. Thankful the weather is holding out.
Ranger_Rocks
Wandering
Wanderer
How long is that 1/2 inch pipe?
I need to get one.
This one is 18 inches.
I used 24 inches to make sure I had adequate reach and extended out beyond the frame as shown below. This setup applies a solid nearly 90 degree torque on the OEM cap which broke loose easily.
This pic shows the full 24 inch length. The red at the very bottom is a plastic thread protector cap on the near end.
