- First Name
- Dave
- Joined
- Jul 25, 2019
- Threads
- 342
- Messages
- 27,112
- Reaction score
- 137,224
- Location
- Back Home In AZ!
- Vehicle(s)
- 2023 Ford Ranger Tremor
- Occupation
- Retired...Full Time Slacker
- Thread starter
- #46
I think I finally have it narrowed down to 3 recovery boards. One thing I need to take into consideration is these will be used mostly in my Bronco. It’s a 2 dr and doesn’t have much cargo room but the rear seats will be folded down probably 80% of the time. Rough dimensions with them folded are 46” x 43” and most of the boards are 47”- 48” in length but could always be placed Kitty-Corner but that takes away a lot of center space.
FieryRed (Sids) Boards: 45X13….$100
Good reviews which some have actually used them and reasonably priced with a 2 yr warranty
https://www.amazon.com/FieryRed-Tra...coding=UTF8&psc=1&refRID=CRECXY5H174Q9FH8YCVP
Maxsa Boards: 48X14.5….$132.00 (priced on another site)
Very good real world reviews. I actually slummed over to Tacoma World and did a search there. These were mentioned by several as being very good boards for the price and several have used them on more than one occasion. 1 yr warranty
https://www.amazon.com/Escaper-Trac...ncoding=UTF8&refRID=TX29YFB6PA4GNJHPN17J&th=1
MaxGrip Boards: 42X12….$130.00
What I really like about these are their size. They just might fit width wise and will definitely fit length wise. Plus the lugs are replaceable. Warranty ?
Is there any downside to these having just 2 channels and the lugs all in a row opposed to the others where they’re more in a spread out pattern? I’m leaning towards the MaxGrip & the Maxsa but more so the MaxGrip only because of it’s size….Thoughts?
https://www.amazon.com/dp/B07SDBLNN...0DER&seller=A1XHBJGGS102AI&tag=offroad-shp-20
They were designed in Australia and are based in New Zealand and have a lifetime warranty. I called the vendor who I purchased them through and asked a bunch of questions mainly how do you go about submitting a warranty if needed? She said the main distributor is based right in Ontario, CA and they use to handle the TRED boards but since ARB now has them they switched to the Exitrax. So far none of the boards she has sold have had any issues and they only require you submit pictures of the damaged boards for warranty. If there’re questionable they might have you return the boards but usually only require pictures.
