Recommendation Please: Coilover Installers in SoCal
vince
Vincent
CA
Ford Ranger
Work
Starting with a completely stock 2020 Ford Ranger. Just bought an Eibach Stage 2 kit for it (E86-35-048-01-22). I'm in Los Angeles and although this is a relatively straight forward install I'm looking for recommendations for a shop that has experience specifically with our generation Ranger.
I've read cautions about needing to ratchet strap the steering spindle/knuckle to the upper frame mount so the inner tripod joint doesn't slip out of its internal housing inside the boot which won't be visually obvious if that happens. That's got me nervous about what other gotchas there could be.
NotBudule2
Robert
21 Ranger
You can do it by just removing the lower control arm bolts , no need to mess with the axle...
Ill see if I can find the thread...
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
You can take off the nut on the axle (cv shaft) and that will allow movement without damaging it. Pretty simple once you figure out that part. Rest is just basic wrenching.
ScarzRanger21(2.0)
Eric
Auberry, CA
2021 Ranger 4x4, 2019 Ranger Fx4
Electrician
Any shop in your area that works on trucks should be able to do it. It’s really not a difficult job, I did my wife’s truck and it took about 20 mins per side. I used a block of wood to rest the knuckle on.
I had my dealership do it when I took it in for an oil change. I made sure I had the snap ring set to the height I wanted first.
veedubtuner
Morgan
Tulsa, OK
2023 CG XLT Scab FX4 Ranger
VW Parts slinger
As someone whose never worked on anything other than VW's, I just did this and I found it was fairly simple. I removed the Calipers and loosened the axle nuts as to not put stress on the CV and replaced the axle nuts with new putting things back together. I used this video as a guide. :like:
