coilover
RussB
Russell
Laurens
2011 f 150
ive got 2019 ranger rwd has anyone put coilover shocks on theres that werent fox shocks
I'm 4WD and went with Old Man EMU but that is a lift and probably not what you are looking for.
quangdog
Kimball
Meridian, Idaho
www.youtube.com
2019 Ranger Lariat FX4
Your truck is a 2wd ?
No, mine's a 4WD. My understanding is that the Eibach coilovers will lift a 2WD slightly higher up front because there is a bit less weight - maybe an extra quarter inch or so.
gcan
quangdog - based on my research I’m leaning to the Eibach for the front versus the leveling spacer I have installed now, looking for a improved ride.
I have replaced the rear with the Fox 2.0 and it helped but still washy.
Do you know Which Eibach model number you got for the front? Adjustable or fixed?
quangdog
Kimball
Meridian, Idaho
www.youtube.com
I picked up these coilovers for the front:
https://eibach.com/us/1935/E86-35-048-01-20-FORD-Ranger-pro-truck-coilover
Previously I had a Rough Country 2.5" lift up front on top of stock FX4 shocks. These coilovers offer a smidge less lift (lost about .5") by default, but they can be adjusted pretty easily on-truck. I left them at their factory setting, and am VERY happy with the ride now.
When I installed these coilovers, I already had the Fox 2.0 shocks in the rear. I drove it for a short while with Eibach up front and Fox in the rear. If you already have the Fox 2.0 shocks in the back, you can just leave that as-is, but I actually swapped the Fox 2.0 shocks in the rear for the matching Eibach shocks instead. The Eibach shocks are a smidge firmer than the Fox, but I can't say for sure that I really can tell a difference in the ride between the Fox and Eibach rear shocks. I just wanted everything to match.
Here are the rear Eibach shocks I installed: https://eibach.com/us/1935/E60-35-048-01-01-FORD-Ranger-pro-truck-sport-shock
