Rebel Series Muffler Delete Exhaust Kit
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
What size is the ranger exhaust? 2.5”?
Doc
Doc
Live oak fla
Hmm.. sounds decent. Might have to try
m.
You will love it..I’ll have a drag strip burnout and launch
video Jan 5th in Gainesville.
Regards
Doc
Doc
Live oak fla
The tailpipe diameter is 2.5 “ muffler diameter is the same..I had a shop do it here, took them 10 minutes and $80.00 out the door...It sounds exactly the same as my wife’s 2020 HPP mustang (active exhaust) on cold start.
Regards
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
Regards
Thanks Doc, appreciated
ColoRanger
Cody
Actual tailpipe exit is 3”. Muffler Inlet and outlet are 2.76” and 3”. They are kind of tricky the way they come out. That’s why I opted for the Apollo. Makes it solid 3” for endless possibilities with a straight through or center in center our muffler.
Adding pictures to show what I mean-
inlet with factory clamp showing how it steps down
outlet showing it’s step out.
you can get away with 3” piping or muffler for replacement, it just takes some messing with it. My 17 5.0 was the same way
Doc
Doc
Live oak fla
Thank you for the correction, I just did a quick tape measure check, my old eyes are not that
great..
Regards
Thanks for the pics.
I just remeasured my tailpipe exit , it is 2.76” ID by micrometer.
My muffler measurements were off as they were cut flush.
Regards
ColoRanger
Cody
great..
Regards
I just knew because I put an old MBRP 3” tip on it before I changed to the AFE setup. I measure it out when I was looking at options! When I did the varex variable muffler on my 17 5.0 F150 I ran into the same thing.
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
Hmm.. so what size would it be if you cut it flush on either side of the muffler?
ColoRanger
Cody
That’s where it’s wonky, because a 2.75” would probably be perfect, but a 2.5” or 3” pipe could be made to work if you’re welding in pipe. If you want to clamp it on....Maybe a 2.5”
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
Perfect, that’s what I needed to know. Thank you!
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
Ok I just re measured the muffler cuts flush, one end is 2.5”, the other end is 2.25” these are ID measurements.
Regards
You are the man! Thanks guys. I have a leftover 2.5” piece but it’s only 20” long and that huge muffler is 23” so I’m gonna go to the exhaust shop tomorrow and either get a piece and do it myself or if he wants to do it for cheap enough then have them do it.
Doc
Doc
Live oak fla
You won’t be disappointed..( and you will lose 20 lbs of ugly) :)
Regards
HenryMac
Mech. Engineer - Retired
4 Banger Exhaust 101
  • Big Muffler W/ Tailpipe Resonator = Throatiest Possible Sound
  • Small Muffler W/ No Resonator = Ricer Sound
  • No Muffler No Resonator = Wow, That is One Big Weedwacker
