Rear shock bolt worked loose
nate237
Nathan
Moore, OK
2022 Ford Ranger Lariat Tremor
Solutions Architect
FYI, I had a weird rattle in the back end on my 22 Lariat Tremor. Had one of my kids bounce it up and down and I discovered the lower mounting bolt on the driver side rear shock was flat out loose and moving. Not sure if not properly torqued at the factory or what, but I don't see any type of threadlocker on it. I snugged it up tonight and will hit it with some tomorrow.
Anyway, just thought I'd give everyone something to look at if they were under their trucks.
myothercarizahearse
Cleveland, Ohio
Unretired
When I replaced my back shocks there was a loose nut under the truck :crazy:and also the bottom bolt on the passenger side shock was loose. there was an occasional thunk that went away afterwards. I always thought it was just junk in the bed
GitRDone
Andrew
Orlando Fl
2020 XLT
Real estate management
I checked and my shock bolts were tight, however
my spare tire was a bit loose so I tightened it up. I recently installed new tires and reckon that may have happened when they serviced the spare.
Hi Nathan,
Please file a formal complaint with Ford Customer Care. This should not have happened to a stock truck....
best,
GitRDone
Andrew
Orlando Fl
2020 XLT
Update on clunk in rear: Still there after tightening up the spare tire. Upon further inspection, I found the support chain for the spare tire was unsecured and thrashng about. Probably should have deployed the spare and properly secured it, but I took the lazy route and hooked one end of a short bungee cord to the chain and the other end to a frame rail. No more weird noises, so calling it fixed.
HMG03
Calvin
New York
2021 Ford Ranger Tremor, 05/06 ZX6R 636 Stunt Bike
Firefighter
I had the same issue recently, but I just took it to the dealership instead of crawling under the truck myself.
