ranger engine cover
ranger7424
Allen
Arizona
2021 Ford Ranger XLT Sport 4x4
I have tried from two sources to get a engine cover for My 2021 Ranger Super crew xlt and each time they have stated that they do not make one for this model. Both times I tried to buy one from a Ford Delership. The engines are the same regardless of trim level right ? They have the covers for the Lariat model only. What iam I missing ?
I put this one on my Ranger, it looks great and the critters cant chew through it. More worth the price than the foam one from Ford:
https://www.jcroffroad.com/product/RG4GNC.html
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
I like the color match, mine is just the basic black powder coat, not sure the blue would look good in there.
Sure it would...and create multiple opportunities for you to buy other color-matching accessories/parts!
lukdeg
Luc
Edmundston
Ford Ranger lariat 2023 Cactus grey
paramedic
told my dealer I had water on top of engine and truck had a missfire but code disappeard, got an engine cover under TSB
SSM 51239 2019-2022 Ranger - Illuminated MIL With Misfire DTCs/Water In Spark Plug Wells And/Or Corrosion On Ignition System Components Some 2019-2022 Ranger vehicles not equipped with an engine appearance cover may exhibit an illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTCs) P0300, P0301, P0302, P0303, P0304 and/or P0316 stored in the powertrain control module (PCM). This may be due to water build up in the spark plug well(s) which can lead to signs of corrosion on ignition system components. To prevent reoccurrence, an engine appearance cover must be installed on the vehicle. Currently, the engine cover (SPN: L1MZ-6A949-A) is not available to order and a new engine cover kit is being released. Repair the vehicle by replacing suspect ignition system components and schedule an appointment with the customer to have an engine cover installed when the engine cover kit becomes available in April 2023. Monitor OASIS for updates
source:
https://static.nhtsa.gov/odi/tsbs/2022/MC-10228855-0001.pdf
