Quick Disconnect Sway Bar
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Interesting. I might be in for a set after you get some miles and test them out for a bit.
A fair and simple design, I like it!! Just be aware I am you next customer if this works out well!!!!
Porpoise Hork
Bret
Houston
IT
I like the idea of all metal end links, however I see potential issues with excessive wear and/or binding due to dirt contamination. This could lead to premature failure at the mounting points for the bar.
RVA Overland
Eric
Richmond, Va
www.instagram.com
2019 Ranger XLT
very innovative. That's awesome. Once you get some testing done would love to see the difference it makes as far as flex and off road capability.
Caluke
Caluke
Lucas
Automotive tech
Yeah I had the same thoughts. This just seemed like the quickest and easiest to test with. I will have the parts for V2 tomorrow. It will have spherical rod ends with a Teflon liner, should be much more durable and longer lasting.
Any updates on this?
RVA Overland
Eric
Richmond, Va
www.instagram.com
2019 Ranger XLT
It is intriguing. Has anyone measured how much more flex this would give the front end?
JoBo
Joshua
USA
My first attempt at a quick disconnect sway bar end link. No tools required and really easy to remove.
Have you perfected this system yet?
Yes...any updates? I was wonder how the reconnect would work if the connectors aren't exactly lined up...
Caluke
Caluke
Lucas
Automotive tech
Sorry guys been super busy with other projects. I made a V2 with much stronger rod ends and stainless pins. Had it on the truck for a couple of thousand miles without issue. I will post up some pictures of it tonight. The sway bar isn't all that stiff, you can push or pull on the end link to align it as long as its within about a 1/2 inch.
RCMUSTANG
Ray
Los Angeles
Any idea on cost yet?
