Question regarding automatic headlights (2020 XLT)
shockea
Eric
Salisbury, NC
2020 Ford Ranger Super Crew 4x4
Teacher
Yesterday, took a little drive along the Blue Ridge Parkway in western NC - at least part that is open with the Helene recovery. Along the trip were a series of 4 tunnels. They were short, but not well lit, unlike some interstate highway tunnels. I've gotten into the habit of leaving my headlights set in the Automatic zone. Its very convenient, especially with the auto bright feature. So, no worries, right? However, when we got into the tunnel, the headlights remained in the normal "Daytime Running Lamp" mode, which was not enough light, and I had to manually switch over to regular headlights each time.
I was under the assumption that the headlights worked simply by ambient lighting. In other words,light level drops (i.e. night, parking garage, tunnel) and the regular headlights will come on. Is this not the case? Is there a delay that I wouldn't have had time enough to contend with?
Curious, more than anything. Thanks in advance!
Automatic headlights will turn on after a set period of time when going into a shaded area. How long exactly? I don't remember the exact number, but it is usually around 5-10 seconds.
Yeah there is a delay, don't know how long it is either. When I drive into my garage it takes a bit before my headlights come on. It's probably there to keep overpasses from flashing your headlights. Haven't seen anything in Forscan to adjust it either.
Try changing this setting - BCM
To my knowledge this is untested
Note: Factory Hex (As-Built) for this line is:
0100-0003-0058
So try changing it to (1) as follows
0101-0003-00xx
Once you write it the last 2 will change to a different check sum (automatically)
There are mote settings that you can try if this does not work
Its strange though as I don't drive in tunnels but when I transition into my garage the headlights kick on fairly quickly and my setting on this line is set to the factory of 15-Seconds
dozxab
Prescott AZ
There is a slight delay. When it is a dark and rainy day, mine will turn off and on so I throw a small rubber cupholder pad over the sensor on the dash.
Doogie
Iota, Louisiana
2020 Ranger Lariat 2wd/ 2003 F150 Lariat FX4
Re(tired) Electrician
Mine come on when I pull into my shop, about 2 secs, but I'm going slow so there's probably a difference when at hwy speed
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
There is some delay for sure, but I don't know how long it really is.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
I can set the delay from my steering wheel controls. Or you can go totally manual on the dash switch.
VAMike
2019 Ranger Lariat SuperCab
No matter how they configure it, you'll get annoyed at some point. One of my other cars switches the headlights on and dims the dash going under an overpass, then waits like 15s to go back. I prefer the behavior on the ranger.
I prefer the way my Frontier is. No automatic headlights and therefore I don't have to give a damn
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
I just turn them on manually and don't use the automatic setting. Lights stay on under overpass. I do use the auto setting when high beams are needed and find that feature satisfactory.
