Plywood Topper?
Tinkerer
Canada
Ranger XL SuperCab
So do I go with an ARE, or Leer topper?
That was my initial question when looking for a topper. After doing some research, I was ready to make my purchase...........then the world took a turn.
So I was being a bit frugal and came up with the idea to make my own topper, out of plywood!
After a few hours I was able to make a basic CAD model in Fusion of the Rangers bed rails:
........ half a pandemic later came up with this:
There was probably a dozen iterations before getting to this point, many measurements, and a few templates to verify fit. One of the biggest hurdles was realizing halfway through that the bed rails are curved! I had just assumed that they would be flat, but there's about an inch difference front to back.
more templates:
..................and so the build continues!
Rinn69
N. Central Iowa
Retired USAF MSgt
Are you going with the normal plywood or "the good stuff"--Baltic Birch plywood ? A little more expensive, but MUCH better quality with flatter sheets and almost no voids. What will you be covering it with....fiberglass or "Poor Man's Fiberglass", aka--PMF ?
Tinkerer
Tinkerer
Canada
Ranger XL SuperCab
Well I started off with the idea of regular plywood, but soon realized that the Baltic birch plywood is so much better for the reasons you mention. Probably coating with Herculiner bed liner - I know it wont last forever but the goal is to make something that works for the meantime. I will likely get a proper topper in a year or so.
armoredpig
Joseph
VA
2019 Ford Ranger STX
Nurse
Off to a strong start! At first I was like ? but now I think it might be awesome
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
I made a plywood tonneau cover for my old Flareside Ranger. It was supposed to be for a one-time trip, but it worked so well I ended up leaving it on for quite a while.
Tracy Bowman
Tracy
Very creative! Can't wait to see final results! :like:
Tinkerer
Tinkerer
Canada
Ranger XL SuperCab
I think the only downside will be it being quite a bit heavier than a fiberglass topper. But if you can make it exactly how you want it, function properly, and look good then more power to you! Definitely not something I'd be confident enough in my skills to take on. I look forward to the results!
Yes, I think heavier for sure, i'm using about 4 sheets of Baltic Birch which are about 65lbs a sheet, but not all of that is being used, I would think its going to be about 180lbs.
Tinkerer
Tinkerer
Canada
Ranger XL SuperCab
Parts are cut and beginning to take shape, I was fortunate to have my boss donate a half sheet of 1/2" Lexan for my windows, it's a little thicker then I would prefer, but beggars cant be choosers!
I think of of the most challenging aspects will be trying to get a good seal around the windows (windoors!) and rear hatch, I have a plan but only time will tell.
Here's the inner frame with notches (tenons?) that locate in the outer skin.
The front windows are not cut in at this point - just testing the fit.
more test fitting
Tinkerer
Tinkerer
Canada
Ranger XL SuperCab
Thanks for all the positive messages!
Here's a couple more progress shots, glued and screwed all the joints with PL premium adhesive, it was rather messy, and a whole bunch of glue squeeze out which is a real pain to clean up.
Filled all the screw holes with Bondo and sanded smooth.
Then time for a test fit!
One of the side openings is a little larger to accommodate the windoor!
SafetyDan
Dan
Oxnard, CA
Since you have a CNC to cut these you should sell kits. I would build one and glass it.
Tinkerer
Tinkerer
Canada
Ranger XL SuperCab
If you buy a $50 topper you can cut and fab it to fit. But your build is crazy cool.
It's funny you say that because there was an old topper in our yard from an 8'bed full size truck - we talked about slicing it down and stitching it back together - but none of the windows would have fit.
