Overhead console lights
Muffin1
NJ
Anyone know how to or tried to replace the map light bulbs? I want to change to the LED’s.
Not sure if the lens come off-individually or the the complete panel trim. I have the base XL trim.
TIA, Rob.
Muffin1
Muffin1
NJ
Ok great I was hoping the console removed because those lens have a tight fit and wouldn’t think I could get a tool in there to pop them off.
BTW I see you have circuit boards on your lights do you have LED’s already?
McLeadslinger
Trevor
Pikeville NC
Aircraft Electrician
My XLT came with factory LED’s
armoredpig
Joseph
VA
2019 Ford Ranger STX
Nurse
I have LEDs in my STX XL
Muffin1
Muffin1
NJ
armoredpig
Joseph
VA
Nurse
That's interesting cause i have a STX XL and have the regular #912 bulbs not LED's. I'm confused lol.
Maybe it's the technology package? I have BLIS and lane keep too
Muffin1
Muffin1
NJ
Yea maybe that's it i don't have that package, thanks for the reply.
Jason B
2021 XL STX SE 4x2
machinist
Did you open up the panel and confirm they are #912?
Muffin1
Muffin1
NJ
No and i looked at the manual it doesn't list any bulb for the map light (or even a map or console light at all) from what i could see when i had tried looking close thru the lens it may be the glass tube type bulb like this;
And i won't really have a chance to mess with till the end of this week or over the weekend.
Muffin1
Muffin1
NJ
I opened up the panel with the helpful tip by member above 'OC4095' and as my pic below shows it doesn't have serviceable bulbs , although the lights color seem to be like a incandescent yellowish color not the white color like a led type.
Also i was able to read the part # from the sticker affixed to the top of the circuit board assembly but the parts lookup is not describing or differentiating between a led or non.
On a side note this console is also used on the Focus so parts interchangeability is alive and well at Ford, LOL.
Anyone with a XLT or Lariat confirm the light color as a white or yellowish, mine is a XL.
Thanks.
i have an xlt sport with blind spot etc. and mine look yellow. however, that could be from the clear plastic giving a coloration to it. a lot of older cars and trucks had those style bulbs inside maybe ford is cheaping out. i had an old dodge ram that had those and the light wouldnt shut off. doors closed switch off light still on. so i told my self just pull the bulb out... mistake! i think my finger prints just recently grew back after being toasted off by the hot bulb. :crazy:
