oil life indicator ??
motormike
MIKE
SW FLORIDA
87 ford 150, 2020 XLT RANGER 4X4
RETIRED
so, my question is, does the oil life senses time, but that would be for the synthetic blend... but I use full synthetic..so I'm thinking that indicator would not be accurate ... whatcha think??
motormike
motormike
MIKE
SW FLORIDA
RETIRED
its not necessarily the oil that cant make it past the year...its the contaminants contained within that cause you problems
i'd stick to the year maximum no matter what unicorn juice you're putting in it.
My issue is I only drive it about 2000 miles a yr.
MountainGoat
Missouri
2020 Ranger XLT Sport 4x4
I'm not at 4k since last oil change and showing 25% oil life. Not much driving last year and a lot of short trips.
I'm using Mobile1 "extended life" that's supposed to last 15k miles but I never intended to go that far. It was just the most recommended in the oil thread on here.
RedlyrsRevenge
Sean
Fresno, CA
21 Carbonized Gray SuperCab STX FX4
MH/FE Parts Salesman
Oil is cheap. Engines are not. Oil does break down and pick up various contaminants over time. Moisture would be my biggest worry with low miles like that. Personally I would get some Motorcraft Synth-blend or whatever the OE stuff is and go with that on a 1 year interval. ~$40 a year worth the risk of not doing it?
taildraggerpilot
Carl
Kennesaw, GA
2020 Ranger Lariat FX4, 2022 MINI JCW Hardtop, 1967 Mooney M20E
Boeing Guppy Driver
Oil life is determined by calendar elapsed time, mileage and diving conditions (driving style)
txquailguy
Biologist
Synthetic "whatever it is" does not breakdown....or at least not easily. It does however get just as dirty as any other fluid or oil or lubricant.
daniel3507
Oklahoma
2019 Ranger XLT Sport 4x4
I'm in a similar boat. I can go over a year and the oil life still doesn't say I need a change. I still change it though. Cheap insurance. At the very least it keeps my Ford Pass points from expiring when I do it at the dealership and it keeps them from using it to try and deny any future warranty work I may need.
