Ford Pass Oil Life
Arc Ranger
Palm Harbor, FL
2019 Ranger XL SuperCrew with STX package
So I took the truck in to the dealer on Friday for an oil change and tire rotation. It is now Monday and the Ford pass app still says the oil life is at 43%. Has anyone else had this issue? Do I have to manually reset it somehow? This dealership seems very reputable so I highly doubt they would have not changed the oil and then played it off like they did.
MT19RANGER
JERRY
SIDNEY, MT
has it been reset on your dash?
did you do a Ford Pass refresh? I just pulled up mine and it was updated 15 hours ago, so I clicked the little refresh below my ranger pic and it's now updated.
Arc Ranger
Arc Ranger
Palm Harbor, FL
I personally did not reset anything on the dash, I'm assuming the dealer didn't either.
Regarding the ford pass refresh, mine says it refreshed this morning when i drove it to work. I guess I need to look at manually resetting it on the dash. Seems odd that I would need to do that. It's supposed to be an intelligent oil life monitor, so I would think it would know when the oil has been changed, since it is supposed to be monitoring the quality of it.
MT19RANGER
JERRY
SIDNEY, MT
Yes, there is a re-set on the dash controls, some times they forget to re-set it. Dealing w/ fleet vehicles and all the 100's of oil changes I've had done for companies I've worked for it's just a normal thing that I always check to see if it's been re-set to 100% oil life.
There is no vehicle made with an intelligent oil-life monitor that does an auto re-set when the oil is changed that I know of.
At least it is easy to reset. Both my Honda and 2016 C-Max have a hidden combination of key sequence/buttons/etc to press and hold in order to reset it. On the Ranger it is as simple as navigating to the screen and holding down the OK button until it resets. Just like resetting the MPG stats.
Arc Ranger
Arc Ranger
Palm Harbor, FL
Awesome, thanks so much for the info. I will reset mine on my lunch break today.
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
There is no "oil sensor" that actively monitors oil quality. What it can do, though, is keep a log of how many miles have been driven and what type of driving those miles were. So hard driving will count more against your oil life than highway driving.
