oil filter spun on with a slight wobble
silverflash
Bill
NC
2021 ranger XL loaded
stuff
so i did an oil change on my 2021 fx4 and noticed when putting on the new motorcraft filter fl910s, it went on with a slight wobble. never noticed this before. i snugged it up tight with hand. ran. no leaks and good level. my mechanic friend, ase cert, says no issue. just curious what you all have seen on this. or have you even noticed? i got filters off amazon. hopefully they aren't fakes or something. thoughts?
Phil_R
2024 Ford F150 STX
Retired for now!
I have received some from Amazon as well, however no wobble, screwed on straight. Maybe a defect in manufacturing? If it was me, I would probably replace it, but that is up to you. Maybe for the peace of mind, it might be worth replacing it. Just time consuming and having to add maybe another 1/4 of a quart of oil. Again, it might be a-ok too. Your choice...
silverflash
Bill
NC
stuff
i'm just going to watch for drips. none with the warm up in garage and letting it sit to check level.
Wytchdctr
Doug P.
Westside Htown, Texas
2021 XLT
Retired Military/HR Manager
I was planning on getting my filters from the dealer to avoid this; but it seems they are using WIX right now.... o 0. Id say if it seals it is good, but I wouldn't get one from that seller again. If anything for peace of mind.
silverflash
Bill
NC
stuff
just an update: went to local retailer and got another filter, same fl910s, took the amazon one off, put new one on, went on smooth as butter. now we know. i gave it a 1 star review. if it wobbles going on that means threads are cut crooked, who knows what other deficiencies it has....from now on, buy from local retailer and not online.
