Noticable cab vibration going over 85mph
Steve23
Stephen
Maryland
2020 Ford Ranger Lariat
Software Engineer
Hey all,
First time owning a truck so I'm not sure if its expected (aerodynamics etc) for my truck to vibrate, I'd say intensely, when I'm go over 85. It's almost like its completely fine at 84 but then 85 and above it starts vibrating. The steering wheel doesn't vibrate its more so just the cab.
Anyone else had this issue? I'm still under warranty so I may just take it in anyways.
Thanks!
TomC
Florida and North Carolina
2020 ranger lariat supercab FX4
Family vehicle MX officer
I have the super cab lariat FX4 and was surprised at how easily the ranger accelerates onto the highway coming from the F150; I had no cues going thru 85 mph the first couple times, and I didn’t and don’t want to drive that fast normally. i Have not experienced anything like you describe. I am completely stock, only thing would be any mods?
Steve23
Steve23
Stephen
Maryland
Software Engineer
Nope no mods yet besides some stickers lol
Ranger8729
Ashley
South Carolina
1987 Ranger & 2019 Ranger
Why are you driving that fast? ?
Mine is smooth at any speed I've tested it to. if it is speed sensitive, look to the tires, axles/joints and driveshaft as teh initial culprits. My old F150 driveshaft had some sass at 82mph, and only 82mph ?
Steve23
Steve23
Stephen
Maryland
Software Engineer
I do a lot of highway driving so 80+ is pretty normal lol
Thats what concerns me, its smooth as butter below 85 then out of no where just starts vibrating. Pretty much confirming that I need to drop it off at the dealer for a bit
mlarma
2020 Ranger XLT 4x2
Computers/Networks
Would suggest having video to share as I doubt they’ll want to go out and do 85 to find the issue. Bring a friend as you shouldn’t film while driving :)
Steve23
Steve23
Stephen
Maryland
Software Engineer
Thats not a bad idea actually
mlarma
2020 Ranger XLT 4x2
Computers/Networks
There is a stretch of highway in Texas with a limit of 85, so I’m not gonna throw shade for going that fast, but the fidelity of your tires is very important. There’s a lot of energy at play with a wheel spinning that fast. Resonances are also funny where they’ll just increase seemingly induce vibration outta nowhere. Good luck on this one!
SOHK_Alumni
Win
Tampa
Glorified Mechanic
There are some pretty good vibration/frequency analysis apps out there.
Install one suitable for your phone and familiarize yourself with launching and capturing data with it.
Get your Ranger up to speed and grab some data with the app.
Approx 55 hz vibration will be from the driveshaft, 45 or so from engine or torque converter, under 20 tire/wheel/axle.
Road Force balancing may cure tire/wheel issues as may truing the tires.
Work with the warranty for engine/transmission/driveshaft vibrations.
Hi Steve,
At that speed you would have more of a buzz if driveline related....best check tire balance..
best,
Steve23
Steve23
Stephen
Maryland
Software Engineer
Hi Steve,
best,
I was thinking it could be that.
Steve23
Steve23
Stephen
Maryland
Software Engineer
im sure all this high speed driving is separating the tire plies.
to confirm this, go even faster and see if you blow the tire.
familiarise yourself with the 4 way flasher button. you'll likely need it when the tires shreds to safely slow traffic behind you as you wrestle control towards the shoulder of the road. dont roll it like the explorers used to do. no one wants another lawsuit.
once there safely pulled over, you can learn to lower the spare tire, which will be dirty, sized differently than the stock tire and limits you to 50mph.
the jacking points are clear in the manual so you should be ok doing this on your own. toss the trashed tire and rim into the bed, yay for pickups and head to the tire shop to buy tires that are more suited to high speed driving. stay away from A/T or off roaders. stick to S rated or more.
no need to go to the dealer IMHO, unless you think it's a simple balance issue and they can road balance them to the higher than legal limits you drive at.
I know you're poking fun but the speed of traffic is around the same. I'm not some asshole wizzing by people.
My old Ranger came with a bad front shock when I got it. Displaying pretty much the same behavior. At about 75mph the hop was pretty severe.
I think the shocks that come on the Ranger cover the bare minimum to say, see you got shocks and they work. Push them a little bit they show how inferior they are. Your mileage may vary though
Showmeguy2020
Erik
Long Beach, CA
2020 Ranger XLT FX2, 2017 Honda Magna 500
I'm going to second the balance diagnosis. Had a 2010 Ranger before my new one and had this issue when AT tires were installed. Although tire installation isn't rocket science it's easy for inexperienced techs to be off just a tad. Also if you're not feeling it in the steering wheel it's probably coming from the rear. Good luck! Oh yeah, you may want to install a parachute to help slow down from those tire shredding speeds. BTW I regularly hit 90+ mph and haven't experienced any vibrations except for my little giggle as I go by the Taco's and Bow ties!
