NO SHUT OFF
mustang marty
new england
2019 ranger stx sabertooth , 04 stang ragtop 40th anvrs. , 66 stang fastback 2 plus 2
A happy retired guy
Just thought of it but my Ranger has not shut off at a stop light for over one year now . Not complaining just do not get it . Maybe because 90 percent of my driving is short trips . Believe me I am happy ! Any ideas ? Also no device is charging in ac plug .
NotBudule
XLT
Does it show disabled on the dash ? with the line through the symbol ?
Or somebody unplugged BMS , or 2019 battery is iffy...
mustang marty
mustang marty
new england
A happy retired guy
nothing on dash maybe battery is down because of the short trips I take . They say heat is worse than cold on batteries
NotBudule
XLT
I think thats even truer on these new batteries , a few here have added trickle chargers to help ,...
12Bravo20
Missouri
2020 Ford Ranger XLT FX4
Tow mode and sport mode both disable the auto start stop system.
Usually if the battery is getting weak then you will see a crossed out A on the dash. And when you scroll through the menu you will get a message stating the A.S.S. is not available due to battery charging.
I get that in my 2020 Ranger if I haven't taken any longer drives in it. Short in town trips aren't good since it doesn't allow the battery to fully charge like a longer drive will.
maybe the truck was programmed not to do the ASS?
cfhgarza
Ohio
2020 Magnetic XLT 301A
Press and weld set-up
Mine stopped working because of a bad BMS sensor/battery. Both replaced under warranty.
Other symptoms. Getting the "deep sleep" message on Ford Pass every time I trim off truck. Radio/power points would turn off 30 seconds after turning off truck
Markubis
Nashua, NH
Mechanical Engineer
If I don't have my foot too far on the brake pedal then ASS doesn't kick in. The same goes for my VW Tiguan.
MartenSawtooth
Aaron
Boise, ID
'23 Ranger XL, '00 Ford Expedition, '04 Sentra
Mine was disabled from factory. I have a '23. Seemed like all the '23s on the lot had A.S.S. removed. I feel 14 snickering every time auto start stop is abbreviated.
Glocker
Boca Raton
Things that disable the auto stop/start:
  • Manually disabling it
  • Engine not up to operating temp yet (lots of short trips, some people never experience it working)
  • Battery below the threshold
  • Tow mode
  • Sport mode
Tom_C
Virginia, USA
System Admin, Retired
Yeah, you can look in the instrument panel, I think under fuel economy (but not 100%) and it will show why ASS may be off. Probably says off due to charging, which points to the short trips or bad battery.
If I recall, some of the new trucks had it deleted because of the chip shortage?
