TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 46
- Messages
- 3,975
- Reaction score
- 10,020
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
I am not surprised that it is being replaced instead of repaired, and that the failure was catastrophic.At the cost or that mine's broken?
Cost is a little lower than I expected.
I do not trust the Ford fluid change schedule (which is NEVER! (150K miles is essentially never)). My opinion is that the transmission is designed to last no more than 150K miles. Essentially Ford is only concerned with making it last beyond the 36K mile warranty.
I do not believe that the torque converter is efficient or built strong enough with adequate cooling capabilities. It overheats the oil. Ford built it "just good enough".
I have heard clanking noises emanating from out of my transmission on occasion when the torque converter can't decide to lock or unlock. It gets confused. Maybe it is a possible software problem.
As an old SW/HW developer, I can tell you it is very easy to code something to do a given thing, but it is very difficult to cover all the possibilities of it doing something that you don't want it to do. You must think of every possible scenario and code for it.
You must also code for the design limitations of the hardware. And code in allowances for less than optimal performance of the hardware. Timing tends to be critical.
Building a reliable mechanical transmission is far easier than building a reliable computer controlled transmission. Instead of having to deal with only a mechanical failure, you must also concern yourself with software errors, computer electronics component failures, power supply voltage and current fluctuations, and proper grounding, as well as the mechanical failures of the transmission itself. The more complicated the plumbing the easier it is to stop it up.
Of course this is all simply my opinion. but it is based up 40+ years of experience in the I/T technology industry.
Me, I am going to err on keeping fluid in the correct temp range, changing it every 30K miles adding the deep pan that holds an additional 1.75qts, and adding a proper dipstick to make the maintenance of the transmission easier.
And I may still suffer the same result as you. Only time will tell. But I will know with certianty at the end of this journey whether it is a service related or design related problem.
On a related and similar note I added a catch can at 3K miles. I just took a trip of 500+ miles on interstate. Before beginning the trip I checked my engine oil level (1500 miles since last change) and emptied the catch can. I noticed that the engine oil level had gone up by .5" on the dipstick. First time I have seen it happen on my truck.
Upon returning home, the next morning I checked the oil level. It was down 7/16" and just 1/32" or so above full! I then checked the catch can - which was found to be full of water and gas mix with a trace of oil. The first 1500 miles on this oil was primarily short trips of 50 miles of less. The second trip was a long distance run.. Ambient temps were in the 30's at night and 50's in the day.
Something unusual is going on inside the 2.3L ECO boost engine as well.
My old 2005 Ranger with a 4L V6 has a closed PVC system as well and the oil level remains constant between changes.
- T
