TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 46
- Messages
- 3,971
- Reaction score
- 10,009
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
There are much better solenoids and parts out there for the 10R80 transmission. I had 18K miles on mine when I had major problems. I replaced the fluid 3x in 9K miles. It is now shifting perfectly... and 92% of the fluid is new (I pumped it out through the dipstick and could only pull about 50% of it at a time.). I also added LubeGard Platinum at each drain and fill. The last change I installed the PPE deep pan, and changed the filter as well. It is back to shifting normally.
It takes a couple hundred miles for the software to adjust to the speed of the new solenoids and change the shift patterns. Give it that much time to see if the shifts smooth out.
Sounds like you found a transmission mechanic who knows his stuff.
