Problem with my 2020 ranger
Chmatisello
Pennsylva
2020 ford ranger xlt
Corrections
I bought a 2020 ford ranger xlt in December of last year and since I’ve purchased it from time to time when making sharp turns while accelerating slightly there is a weird loud grind noise coming from what sounds like under the gas pedal, no mechanic I’ve seen has been able to see anything wrong and I can’t get it to make the noise for a mechanic to hear it just happens periodically, what could be the issue or has anyone else had a similar issue (stock 17in wheels, 265/65/17 tires, 2.5in leveling kit)
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
Most likely the ABS is kicking in. It can be a bit intrusive on the Ranger while turning and accelerating.
Chmatisello
Chmatisello
Pennsylva
Corrections
what exactly does that mean and is it a problem
RangerBill
PA
ABS - Anti-Lock Brake System. One of its functions is to prevent a tire from losing traction during acceleration. It will rapidly pulse the brake on a wheel that begins to break loose. That is probably what you are experiencing and is normal operation under those conditions.
Cabose-1
Eli
Student
Yes i would think the abs is kicking in. These trucks are super super tight. They do not, can not turn at high speeds to save their own lives. I have tested that on open parking lots. Anyway, it is probably the traction control and everything else kicking in to keep you driving straight.
Hethern
Jay
Shallowater, Tx
2020 Race Red Ranger
Communications Technician aka (Phone Man)
I have noticed on mine that it doesn't happen when Traction Control is turned off.
Brett Fields
Brett
Brooklyn
2021 Lariat FX4, Blackout, Tow
Paramedic
I remember my first time....:D
