Miles to go calculation
chasbo
Charlie
Washington state
2020 Ranger Lariat
IT
I don’t understand the miles to empty calculation I am getting. I’m towing a travel trailer, getting 12 mpg. I stop to fill up and the Ranger fuel monitor then says I have 240 miles to empty. That seems to indicate I have a 20 gallon tank. Why it do that? I don’t trust that anyway, especially when towing but I find it curious. Maybe I missed the memo but I’ve never seen anything that said we have an 18 gallon tank with a 2 gallon reserve.
Rp930
Denver
It could have a built in minimum. Is it exactly 240? And what happens as you drive?
RangerBill
The stated capacity of the Ranger gas tank is 18.8 gallons.
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Isn't that calculation based on the previous tank's fuel mileage? If you did well the tank immediately preceeding, you'll get a higher guesstimate for your current tanks mileage.
I think. ?
I think. ?
It is. When you fill up it calculates the mileage and the gallons from your most recent trip. Then the next time it will be different based on that trip. It's based on speed and steep grades which will effect your mpg and flat steady driving (without traffic lights) and downhills which will give you better mileage.
Jason B
2021 XL STX SE 4x2
machinist
The device that calculates mileage went to American public schools and isn't good at math.
Seriously, it's all guess work. There is no way that it knows exactly how much fuel was put in, or how much is left. And usually the instantaneous MPG and life average MPG are off by 1 mile or 2.
Not necessarily true.:wink: If you use this fuel calculation adjustment you can get it exact. After doing this when I fill up and using the Fuelly app mine come out right on the money to what my dash reads. Sometimes it may be a tenth or two off but pretty darn close to perfect after adjusting it.
https://www.ranger5g.com/forum/threads/fuel-calculator-adjustment.2996/
thorn726
thorn
Berkeley CA
2019 Ranger xl
the tank is 18 gallons. (or 18.8 it seems, there are conflicting reports out but likely 18.8) The miles to go will actively adjust to how you are driving. It can adjust by quite a bit when shifting from city to hwy miles. If i've been driving in town for awhile and fill up as i leave for a road trip i'll watch the miles to go and mpg adjust over the first 50 miles or so. I'll leave home with 363 to go and in 70 miles have 330 to go... it's making estimates and adjustments constantly and assuming you'll get better than the 12 some of the time
thorn726
thorn
Berkeley CA
2019 Ranger xl
It is actually 18.8 gallons.
you know i thought the manual said 18.9 then when i search online it says 18.0. I see on here others say 18.8 and also "All the Ford literature says 18 gallon tank, but interestingly enough in the FORscan software the default says 19 gallons..." /// I think it is likely the 18.8 or 9 is correct i still havent filled up from totally empty to say for sure but yeah i think it is more than 18 ill edit that
ccasanova22
Lakeland, MN
2022 Ranger XLT Tremor
The tank is actually 20 gallons. I’ve run it to where I put 19.5 gallons in on pump cut off, and the truck still ran well on steep inclines, declines, and corners, indicating there was at least some gas in the tank.
Do I recommend it? No, but if towing and all you can find is a gas station 15 miles past 0, it definitely can make it. The reserve feels like it’s 2 gallons.
