Mice
? That cost money. lol Wouldn't pre-treating it here and spraying it down with a hose do the same? ?
That works too...just avoid #4 (?) plug...that one in back has it's own water reservoir...
Sojourner
Maryland
2023 Ford Ranger XLT Tremor
Retired Army / Disabled Vet
I just did this modification 3 days ago.
I agree working space is very limited.
You may also want to do the rear vents behind the back seat. I've had rodents enter there on a camping trip in northern Vancouver Island. I haven't done that myself, but I will be doing it soon.
Here's my after pic for the cabin air intake vents. I used standard aluminum screen from Home Depot and butyl tape, which I had on hand for RV repairs.
I went a similar route. Used this mesh from Amazon:
6 Pack 12Ɨ8 Inch Wire Mesh Screen, 20 Mesh Stainless Steel Mesh, Sturdy No Rust Metal Mesh Screen for DIY Projects, Cage, Vent, Garden, Window Screen, Filter Mesh https://a.co/d/6vf45LL
Cut a sheet into a trapezoid shape and hand bent as best I could to form it to the shape needed. Then used flex tape on the left and right edges. Left the edges with burrs all around so that it might discourage a mouse from trying (thinking maybe anti-mouse barb wire?). The burrs did a good job of giving me multiple diabetes blood stick checks....
The other filter suggestions just seemed too cumbersome. Until a plug n play kit becomes available I think it's a 95% solution. Thank you for the suggestion, @EJH. :thumbsup:
Now to remember to a) spray the engine compartment with Grandpa's pee and b) check the filter once per month to see what's up. Or, hopefully, what's not up.
fORdEGON
Ryan
Grants Pass, Oregon
2020 Ford Ranger SuperCab Lariat FX4
Excavation Contractor
Opened up my truck today after it sat over the weekend on a job site and spotted a mouse coming from the passengers floor board area and then hopping into the back seat and disappearing. I need to take all my tools out to clean and investigate. Does anyone know where the most likely spot is to check for a nest? How do they get in is though cabin air filter opening ?
Trustable
4Runner
Check the vents behind the rear passenger seats that balance the pressure when doors close. That’s where they were getting in when I had my ranger. Also check the under seat storage they may be building a nest under the jack cubby. If you check those and air filter that should rule out most of the entry points that are known about. I would take a look at the thread @AzScorpion mentioned in his comment. A lot of us had issues and there is a lot of pictures and solutions.
There were 3 threads on this so I just merged them all together. This way it makes it easier for others to find and see what areas others have sealed up. I'm going to have to keep a better eye on my truck down here since I'm bordering the desert now and there's more critters down here. Up in Goodyear I never saw a mouse in 12 years but I was farther from the open desert and it was so hot up there I think they just spontaneously combusted. lol šŸ­šŸ’£
Trustable
4Runner
Ah okay, I didn’t read your post right I didn’t realize you merged them. Yeah I would definitely take all the cowls and rear seats off to put some hardware cloth around the vents and openings if your bored one day.
spontaneously combusting mice? Sounds like a product ACME would sell šŸ˜†.
TxOTRRanger
Clay
Elwood, Texas
This, and an ACME product that Wile E. Coyote would probably use to try and catch the Road Runner..........beep beep lol.
Today's Acme is Amazon. lol šŸ˜†
Similar threads
