Limp mode, activate!
fusseli
EE
2/2019 build date, 4k miles
Cruising along on the interstate warnings go off for collision avoidance disabled. Engine light and the wrench light both illuminated. Low power mode activates; low engine power state that is not just power but also rough and shudders to shift. Didn't overheat or anything and idles smooth.
Called Ford Customer Care, they seemed alarmed but said check the manual and take it to a dealer, the most help was informing me of the tail light recall is also just posted. Nearest dealer doesn't care and can't get me in until late Monday, can't give me a loaner or even a ride home to drop it off today.
Ford Pass app says low power mode means the vehicle doesn't need to be towed so I drove it that way 100+ miles on the interstate in bad weather to get it home. Restarting temporarily clears the errors but they all quickly come back. Noticeable hot vacuum cleaner smell upon arrival.
Needless to say I'm not thrilled!
weasel1
Pembroke, Ontario
Nuclear Operator
Yikes. That's not good. Hope it turns out to be something simple.
Hi Fusseli,
Sure sounds like you have an electrical connector that is not fully seated. Hopefully the Dealer can resolve quickly!
Good luck!
HenryMac
Mech. Engineer - Retired
fusseli
fusseli
EE
I wonder if the blower motor recall issue is what you are smelling.. and that the electrical issue is related?
More here -------> https://www.ranger5g.com/forum/thre...vac-blower-motor-issue.4727/page-6#post-82707
The smell was outside the truck when we got out, more like hot metal and less like burning or electrical. Could have been unrelated or a coincidence, but the wife smelled it too.
Pretty bummed at the moment, it was the Ranger's first 1500 mile road trip. Bad weather and its time to shine, and the worst time to break down. Glad is was limp mode and not stranded otherwise it coulda been a lot worse. Now it also sucks to be truckless for the weekend with some friends in town, then to limp it to work Monday just so I can limp it to the dealer later in the day. Bah!
fusseli
fusseli
EE
Pretty sure the check engine blinked a few times, which is different than solid on. Blink means engine is misfiring apparently. All of the app and manual guidance it's surprisingly confusing on what to do, it runs so it doesn't need a tow yet my spidey sense says don't drive it like this.
HotPepperRedRanger
Kevin
2019 Ranger Lariat 2015 Ford Edge 2012 Toyota Camry
My wife’s Edge, with under 3,000 miles had a similar issue, my initial phone call was met with similar results but luckily I was within 15 miles of the house. Each time the warnings and limp mode activated I pulled over shut it down, waited a couple of minutes restarted and would get a couple miles before it all happened again. Got home called a different dealer who sent a tow truck within the hour (Saturday afternoon). Later that afternoon service department called and said it was a faulty throttle assembly or connection and it would be ready Monday after 12:00. No issues since then, hopefully you will have the same luck.
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
OP, I hope you get it all sorted out. That sucks when you can't trust that the truck will get you wherever you are headed.
fusseli
fusseli
EE
The main code is a P061B, ICM torque calculation failure, which was not in the service guy's TSB and common codes list. Looking it up online it sounds like it could be throttle body related.... TBD
Jerry Caldwell
Jerry
Granbury, TX
Ranger Lariat
Retired Architect
Our Ranger did almost exactly the same thing yours did.
We were going home on November 13 from a camping trip towing our Tab 400. I had the cruise engaged with the trailer tow system on as well. All was going really well when we met a white 18 wheeler on this two lane road. The Pre-collision system freaks out and disables the cruise and the tow system. I also noticed a reduction in power for the remainder of the trip. The little wrench appeared on the gauge cluster with the note “See Service Manual” of which the owner does not have. After we got home and let the truck set for about 30 minutes I started it up and all is well now. Next towing adventure I will remember to shut the Pre-Collision system off which should hopefully cure this issue. I have noticed more than once that the Pre-collision system will give false alarms too. Not sure it is a good system to have.
Really like the transmission program for towing. It uses all the gears really well and will shift down to help slow the vehicle on declines, at least until the Pre-collision system freaked.
We have not experienced this fault since. I did call my dealer to see if I needed to bring it in and they said. If the little wrench is no longer on the display they would not be able to check it.
fusseli
fusseli
EE
So upon further inspection they also found a P0300 for engine misfire, which they say pointed to a TSB 19-2246 that said to update the PCM. So, new software, and they send me on my way.
I'm kinda miffed how an early build Ranger sold in 8/2019 could have missed some update and be sold to me with crippling software. All I can do is hope it doesn't do it again. Does anyone know what this TSB actually is, I can't find it anywhere.
@Jerry Caldwell that's strange. Mine happened without towing or cruise on, simply on the highway in bad weather. Pulling off and restart temporarily cleared it but the wrench and limp mode came back two or three more times, each after about 5 minutes at speed on the road again.
MT19RANGER
JERRY
SIDNEY, MT
Well, when I was a fleet manager and ordered over 300+ vehicles "not FORD" direct from the factory and they were shipping all over the US there were 4 recalls/TSBs that had to be applied as soon as they arrived at the dealers due to software and transmission issues. It happens.
