Check engine P29AB P0299, Limp mode
Elgorr4
Elliot
Maine/Utah
2021 Ford Ranger XL
Got into the ranger on Friday night to make a short trip down to the local watering hole to catch some live music, and was greeted with the wrench icon and check engine light. Fordpass said it was okay to drive vehicle but to take it to the dealership. Made the less than 3 mile trip without incident, but "reduced power mode" meant no turbo coming back up the hill (all downhill to the bar, all uphill on the way home. Felt like driving a Tacoma, slow but not terrible. Didn't seem to have a rev limit (wound it out to 6k), but I was never on a road where it was appropriate to go more than 40mph to test if speed was limited.
Today I plugged in the scanner and got codes P29AB and P0299 for turbo wastgate position sensor out of range high, and for turbo underboost. All things seem to point to this TSB:
"Some 2019-2021 Edge/Nautilus/Ranger, 2020-2021 Escape/Corsair/Explorer, and 2021 Bronco Sport vehicles equipped with a 2.0L/2.3L EcoBoost may exhibit a lack of power with an illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTC) P02AB, P0243, P0299, P1464, P25B3, P25B4, P2AB7, P2AB8 and/or P2AB9. This may be due to an inoperative wastegate actuator, missing wastegate actuator e-clip or non-visible damage to the actuator rod. A lower level service component has been released, K2GZ-9G488-B for Edge/Nautilus/Escape/Corsair/Bronco Sport vehicles and LB5Z-9G488-B for Explorer/Ranger vehicles, for service to replace the actuator, actuator rod and both e-clips. When replacing the wastegate actuator, it is important to replace all parts in the service kit. Turbocharger replacement is not necessary to correct the condition."
I'm at 34k so it should be covered under warranty, but I'm a little bummed I now have this big errand to deal with. I am very fortunate that I do not have to drive that often because I live and eat where I work, but it is still a hassle not to be able to leave when I want to. Not that I would be driving much this week anyway with 88" of snow in the 10-day forecast. I have an appointment with the dealership Monday the 2nd. Will update when I know more.
Elgorr4
Elgorr4
Elliot
Maine/Utah
2021 Ford Ranger XL
Finally was able to make it out of the mountains and drop the ranger off last friday. Dealer did some pinpoint testsand determined that the whole wastegate did need replaced. Job was done by Tuesday, no charge, all covered by the standard warranty. They completed all three recalls for the seatbelts and washed it as well. Pretty good experience but wish it wasn't such a hassle for me to get to the dealer and back. Also glad it didn't happen 2k miles from now, would have been over 36k and out of warranty.
onemanlan
Taylor
Birmingham, AL
2022 Ford Ranger LTX
Reseracher
Glad it was a simple & free fix in the end!
Motorpsychology
Prescott, WI
Vagabond
I believe the turbo is considered part of the powertrain, and would still be covered under under the powertrain 5/60, with a $100 deductible, if it goes out again.
Roscoe_t
Russ
2021 Ranger XL Supercab
I had these codes pop up last week. Of course the local dealer is on holiday time, so I won't be able to get in until the middle of next month. Meanwhile, the check engine light has gone out and performance seems to be normal. I assume the wastegate code will still be in the system when I finally take the truck in.
Brianj67
Brian
Canada
2021 Ranger XLT
Firefighter
I had the P0299 and P25B4 codes pop up on Dec 22nd. Found a service bulletin that said to clear codes and test drive under load. Cleared with Forscan and they haven't returned...yet. Dealer appointment booked for mid January. 80k kms but I do have the extended warranty.
