Lift points for floor jack and stands in rear
jflogerzi
Moreno Valley, CA
Never worked on a truck. Going to be installing my rear 5100s on the ranger. What's the best way to get the rear end in the air and securely on Jack's? Diff or rear hitch? Also where should the jack stands go? Rear axle or the rear jack points on the frame? Looking to make this install as easy as possible.
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
They say Never jack from the center diff. I jack from the frame itself just ahead of where the hitch bolts to the frame. Place jack stands on frame rails as well beside the jack.
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
I didn't Jack the Ranger when I replace the real shocks, I only use the Jack to help me push the shocks in place. As long as you are in a level ground, you should be fine.Watch out for the nuts holder's when you install the bolts back. They go inside the holders. I screwed that one up.
Radioman
Kent
Roseville, CA
I have always used the rear diff to jack any rear wheel drive vehicle of mine and put the jack stands on the axle, but... Ford says not to use the diff to lift the vehicle so I guess the frame near the back is the way to go.
Bob902
St. Louis
2021 Ranger XLT
RETIRED!!!!
No need to lift your truck to replace the rear shocks. Easily done without lifting. Two bolts per side.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Why aren't you supposed to use the diff? I always have, haven't broke an axle yet, but I am curious. Wonder what my axles think when I high center them on the pumpkin....
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
using the diff has a potential to deform the cover and cause a leak.
if you're careful and dont catch the cover, you could probably do this forever without issue
if you do catch the cover, time to upgrade ?
Makes sense. I always make sure I'm not grabbing the cover. Grab the flat part at the bottom. Thanks.
Wytchdctr
Doug P.
Westside Htown, Texas
2021 XLT
Retired Military/HR Manager
Maybe the don't lift on the diff was for those with the drain plug that was removed on the newer 5gens?
Wytchdctr
Doug P.
2021 XLT
Feels like you’re grasping for a tie-in here..
Fixed it. Someone replied in between posts. Maybe they don't want the drain plug jamed in via jacking on it.
Grasping complete.
R_B
Robert
Southern Nevada
2019 Ford Ranger XLT 4WD
A good tip I read here was before loosening the upper shock bolts, stick some duct tape on the bottom portion of the captive nut.
It would normally fall down after removing the bolt but the tape will keep it up there.
Put the new shock up in there, stick the bolt in and torque it. Remove the tape afterwards.
For once, I did not drop the nut and have to go scrambling around for it.
MikeyB
NYC
2021 Ford Ranger
I've been using a floor jack under the rear diff (middle) of every vehicle I've owned with a solid rear axle since forever....never had a issue.
As some others have stated here as long as you don't touch the rear cover, you're good to go.
I've also placed jack stands under the tube on either ends. Never had a issue. JMO
