Left headlight adjuster does not change aim
dozxab
Prescott AZ
As in the title, my left headlight adjuster does not change the aim of the headlight. Right side is fine. Could I have gone too far with it at some point? I did adjust them when I leveled it but just wanted to tweak it a bit now that it is getting dark early.
RangerBill
PA
If you are turning the adjustment screw and nothing happens, it sounds like something came apart in the adjustment mechanism in the headlight assembly.
dozxab
dozxab
Prescott AZ
If you are turning the adjustment screw and nothing happens, it sounds like something came apart in the adjustment mechanism.
That is what I was afraid of. Hoping there is an easy fix.
RangerBill
PA
You might try putting slight downward pressure on the headlight lens while turning the screw to try to re-engage it, if it became unscrewed.
Actually, it might be better to push in on the lens while turning the adjuster screw to try to engage it.
dozxab
dozxab
Prescott AZ
It worked! I had nightmares last night about pulling half the nose off the truck to get at it.
