Led Headlight bulbs
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Seems like everything I look at says it doesn't fit our vehicle for some reason?
Anyone have any experience with these or can point me in the right direction. Would really like to find something around 4300k(or a pure white light).
https://www.amazon.com/dp/B07NPMV1H...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
It's almost always because of our dust covers. The back of most bulbs have a large housing for cooling which will prevent the covers from fitting.
Motorpsychology
Prescott, WI
Vagabond
I don't think you will have any luck finding an LED headlight replacement with a 4300k color temperature, maybe in a conventional halogen. Any LEDs I've found are 6-6500k (bright white-blue white) or 3000k (yellow fog lights).
These from Supernova will fit a 2019 Ranger. I have a set of lo & hi beams on my motorcycle, The brightest bulbs out there and excellent upper cutoff for oncoming traffic.
weasel1
weasel1
Pembroke, Ontario
Nuclear Operator
The only LEDs I've seen anywhere close to that color temperature is LEDEagle. Had them in my Colorado. At the time, they didn't quite have the output needed. Haven't checked their recent offerings.
TheKracka
Klay
St. Louis
2019 XLT FX4/2005 xB
I fix things not people
TylerV76
Tyler
Oxford, Michigan
2019 Ranger FX4
Emissions testing supplier
TheKracka
Klay
St. Louis
Posts 340 and 343, 1 page back.
Thank you. Those look mostly white which is good. Anything super blue the pavement absorbs, that's where some of my concerns are. And if I read your posts correctly I'd have to turn off the DRIL function.
*Updated post 349 with fog light LED's, interested in your opinion on those if you don't mind.
TylerV76
Tyler
Oxford, Michigan
2019 Ranger FX4
They are indeed white as opposed to blue. I haven't had any issue at all with the pavement absorbing the light.
I would either disable DRL's all together or swap to the parking lamps only as the Auxitos did flicker for me as a DRL. This was user error. They do NOT flicker
As for those fogs, unfortunately I cant help with those as I haven't tried them or seen any reviews on here for them. I know a few guys were using the dual colors here: https://www.ranger5g.com/forum/threads/dual-led-fog-lights.4230/
https://www.superbrightleds.com/mor...hiteyellow-4500-lumensset-fanless/5123/11670/
Ronbo
Ron
FL, CT, TX
2019 Ford Ranger XLT FX4+
TheKracka
Klay
St. Louis
Auxito Mini's on both lo and hi beams and left halogens in fogs. Had them on since October with no issues at all. Dust covers fit perfectly.
Awesome! Thanks for the pictures, look like exactly the kelvin I was seeking. Held off on the high beam bulbs for now but will order once I know for sure I like the low beams. Might wait for a sale too, The ones I ordered today had 10%off.
RobmJ
Austin
I just put these in both low beams and fogs. Work perfect. Some others here are running them also.
Wow thanks for the pics! Are those the exact same ones in the link ? They are suppose to be delivered tomorrow, I’m excited. Brighter than stock headlight lamps?
TylerV76
Tyler
Oxford, Michigan
2019 Ranger FX4
Thats the ones from the link. They are definitely brighter than stock. If I had to guess Id say 2 to 2 1/2 times brighter.
This is an old pic of stock headlight. This is before my level kit though and much closer to the wall.
Vs Auxito
OxyGenIII
Corey
Minnesota
I decided on going with the L2, I'll see if they work once they get here. Downgraded to free shipping because I am no longer a prime member and dont want to pay for shipping. I will return them if they don't.
So I finally got them in the mail today. Damn near a month later. Amazon's so behind with non essential shipments that eventhough the bulbs were in stock and shipped from Pennsylvania, it still took just about a month.
I have to wait until its dark out here in about an hour and I'll take more pictures.
I also need to look up how to do the foglights. Any pointers for a link?
I was surprised how small they were in person. They fit behind both the low beams and hi beams with ease. Very small heatsink and fan. Can't wait to try them out.
One note, hi beams are a perfect 3 o'clock 6 o'clock, but the low beams on both sides are more like 2 o'clock and 8 o'clock.
TylerV76
Tyler
Oxford, Michigan
2019 Ranger FX4
Take off the skid plate by loosening the 2 rear bolts and taking out the front 2 bolts. You’ll have plenty of access to the fogs to get 2 hands in there and see what youre doing.
OxyGenIII
Corey
Minnesota
Thanks. I honestly thought they were exposed, because when I do my oil I forgot the pan was already out of the way. Haha. Went down to throw them on quick and was like, "where the heck did they go?" ??
