Leaf spring center bolts
navsnipe
Rockland County, NY
What size (diameter) are the leaf spring center bolts for the Ranger?
SOHK_Alumni
Win
Tampa
Glorified Mechanic
10 mm with a 14 mm head to locate the axle's spring perch.
navsnipe
Rockland County, NY
Any suggestions where to source metric center bolts?
Hi Dave,
The spring center bolt has a very rough life and I suggest you not use a "hardware" store bolt. Not sure if the Ford Dealer can get it, but there are many independent spring shops that should be able to help. Old days, it was a Grade 8 bolt but it is likely 10.9.
navsnipe
Rockland County, NY
Hi Dave,
Phil, I am definitely not skimping on these. @SOHK_Alumni indicated they are 10mm with 14mm head, it looks like 3/8" leaf center bolts with 9/16 head are really close to the metric dimensions. I'm going to reach out to a couple of local shops on Monday. Ford's online parts website doesn't even show them as a part on the diagram/list.
navsnipe
Rockland County, NY
Fitzmotor
Gold Sponsor
Saugus
Retired from Honda Racing.
Any spring shop will have them as well as some off road shops, the ones I just got were 3/8" x 2 1/2" from Riteway spring in Sun valley Ca.
You are aware they have a round head, no wrenching area, they are just a pin.
navsnipe
Rockland County, NY
I am aware of the bolt design. Here's what I picked up at a local shop. Trim to fit.
Fitzmotor
Gold Sponsor
Saugus
Perfect!!
I found that the 1/4 shim on the left side that Ford put in to level the vehicle did not allow pin engagement into the rear end housing if I used any pinon angle shims, so I had to find bolts with a taller pin head.
You never stated what you were doing, adding a leaf or two?
navsnipe
Rockland County, NY
Perfect!!
I have the exact problem you describe on the left side. Dealership doesn't seem to understand even though they did the shimming. Pin is not in the hole.
navsnipe
Rockland County, NY
Perfect!!
I can't believe what I found when I got the left side leaf/shim stack apart. The head (pin) was about a half a diameter away from the leaf perch hole. No wonder my thrust angle was off. I will share my findings and how I fixed a TSB 20-2277 install done wrong in the Take-off shudder thread.
