Latest (5/11) forScan has new features
Arron
Arron
Seattle, WA
2019 Ranger SuperCab Lariat FX4 Sport Magnetic
Software developer
Just used the latest version of forScan to add these new options. There are easier to use module programming options now for many modules.
Instant fuel economy digital readout instead of horizontal bar
Power distribution for trail mode
Silent mode (Dark car) menu control
t4thfavor
Chance
OMG I need it, that power distribution one is really cool in the wife's edge. I have an XLT, I wonder if it works on my truck. (guess I'll have to try it.)
How did you add these? I didn't see any significant difference in the interface with the latest beta.
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Please post the as built changes in the main forscan thread.
Arron
Arron
Arron
Seattle, WA
Software developer
Ray I don't know what the as built data is. I just changed the options using the real text that's in the latest version of the forScan app.
Instantaneous Fuel Economy Numerical Gauge (Enabled)
Intelligent 4WD Gauge (Enabled)
Intelligent 4WD Gauge Mode Feature (Enabled)
Silent Mode Control Menu (Enabled)
DTE (Distance to Empty) Sensitivity Menu (Enabled)
I'll do some digging and see if i can get all the numbers though and I will post it in the wiki then.
I did not see that tab when I hooked it up tonight. I'll have to look at it again tomorrow.
Arron
Arron
Arron
Seattle, WA
Software developer
There are 2 ICP options in the list before you run the service procedure. Make sure you select the non-as-built option.
Note this extra option only started showing up in the latest version of forScan from 5/11.
t4thfavor
Chance
Correct, they added the "easy mode" for the Courier and Ranger. I enabled the intelligent 4WD stuff, and it didn't work. The gauge comes on, but the icons don't show which wheels have the power!
So I promptly disabled it. That said, I only tried it in 2WD, so if someone can capture a screenshot of it working, I may try again.
I also turned on the Raptor splash screen in the APIM because I can wish...
VAMike
2019 Ranger Lariat SuperCab
I wouldn't expect wheel power distribution to do anything on a 4wd (not awd).
t4thfavor
Chance
I just figured it would know which brakes were diverting power to which wheels (side to side). Not a big deal, but it's obviously not useful, so I turned it back off.
Andy
Andy
Well the F150 shows power distribution in 2H,4H, and 4L. The truck does manage and alter torque at each wheel. So it should have a readout of that data.
t4thfavor
Chance
It's entirely possible that after a reset on the CANBUS it might have started working then. I may play with it later, but for now I've messed with it enough.
I'm going to see if I can add the off road screen to my dads non-FX4 lariat soon too since I saw that was an option.
Andy
Andy
I’ll test it tonight and do a battery disconnect for a few minutes as well as test out the drive modes after. I’d really like it to work so I’ll try as many different kinds of resets there are.
VAMike
As far as I know it's only really useful on an F150 with 4A (even then it's a novelty). Otherwise it's basically just telling you the status of the transfer case and diff locker.
djrobb
Alexandria,Va
2006 Tacoma 4dr Sport Long Bed
I added the off road screen to my non fx4 and it works
