Just got my FP tune and Butt dyno is not impressed
So how much MPG do you think I could recover going from 285/70/17 Toyo OC ATII (46lbs) and went to 255/70/17 Toyo OC ATIII (37lbs) ?
It is something I am considering once my current rubber wears out.
I'd guess about 1-2.
But you should keep the height. 255/80/17 is only .1 inch taller.
OFC Ranger
Jack
ZR2
What a Waste of ones Hard Earned $$......Buy a Race car but a Tune on a 4 Cyl. Ranger only Makes the Seller Richer......How Much More Power do You Need?
I'm tempted to record myself burning a $20 bill just so your Jimmy's get rustled.
Living The Dream
I haven't done it on my Ranger, but with my Jeep I have 2 full sets of tires and wheels.
If I go from my 265/70/17 Milestar Patagonia MT tires to my more street oriented Bridgestone 245/75/17 tires (both sets are the same diameter), I gain 2mpg and it feels like a LOT more power.
The Milestars are 10 ply so are significantly heavier.
Doc
Doc
Live oak fla
Unleashed …388 lb/ft Torque ….more than my 396 Chevelle ..
Chuck Lau
Chuck
Ohio
2020 Ford Ranger...2005 Mustang Steeda
How many miles will it take to really start taking in effect? Or should I feel a difference right away? I do Hear the intake trying to suck more air in. So the tune did install correctly without any issues.
IT IS A TRUCK!! How Much More H.P. Do ALL you People Expect....BUY a Mustang 5.0 or A Hot Dodge....But a TRUCK? WTF
MoatCarp
Nathan
Houston, Texas
2019 Ranger Lariat FX4
IT Systems Administrator
This has been a very interesting discussion so far!
I had questions in regards to how a performance tune can increase MPG. I see this mentioned a lot as a pro of installing a performance tune. How does that work though? To make more power with less fuel? What are the third party tuning companies (and Ford Performance, in this case) doing that Ford engineers could not figure out to increase MPG and power at the same time?
I promise it is not my intention to suggest anyone is lying. But I cannot figure out why Ford would leave so much performance and fuel efficiency on the table if it meant they could get an advantage on their competition. What's the downside?
Bludrok
Acampo, California
www.ranger5g.com
I'm not an expert on the subject, but my gut says EPA
Colo_Ranger
2021 Ford Ranger XLT FX4
Emissions. A regular production vehicle has to meet standards. You can tune to different standards.
MoatCarp
Nathan
Houston, Texas
I don't think it has to do with emissions/EPA, at least for the Ford Performance tune. The product description includes this message:
"...this part has been determined by the California Air Resources Board (CARB) not to have an adverse effect on emissions when installed and used properly in the application(s) identified in the product description. Under EPA and CARB policy, such parts may be installed in vehicles driven on public roads and highways."
Colo_Ranger
There are rules around vehicles sold, and different standards for tuned afterwards. Harley had this issue with their tuners.
MoatCarp
Nathan
Houston, Texas
If that's true then now I can't get past that there is a regulation that requires a manufacturer to design their vehicle in a way in which it burns more fuel than necessary (stock tune). That seems counter-productive for reducing emissions?
You're probably right, I just don't know enough about how emissions systems work. I need to do some research I think.
Like others have said the EPA has a lot to do with it.
However, it's also not an AND thing, it's more of an OR thing. Kinda like Eco or Boost.
A tune will give your truck higher power and torque accross the band. If you drive your truck efficiently, meaning using as little power as necessary, the truck will perform the same work at a lower rpm throughout, thus saving you fuel costs.
However, if you use the power as God intended your fuel costs will be a wash at best.
