I’ve been using 93 the last 4 fill ups. But I do Have to be honest tho. I did Not install the kN filter. I doubt that’s the problem. I read In other forms like the mustang forms that currently it need sometime to adjust. Idk how true. I’ll give it some time tho. The transmission does feel different in d. It doesn’t lug as much on hills. Which I normally Drop down to S.Interesting. I immediately felt the difference, do you drive it spirited though? I drive it on S mode exclusively. I went from a 7 second 0-60 to 6 second after adding FP tune, roush cai and borla exhaust at same time. If you drive it on D and not spirited, it could feel pretty much the same. Open up that throttle on S after the CHT is 190+ generally closer to 195+. Something to also note is perhaps your truck isn't used to 91 yet, I ran 91 the second I had it, put 500 miles on and then got the relative tune and mods.
Don’t be sorry. This isn’t my first tune per say. I’m sure it’s faster. I think The power is linear and smoother. Before I felt More of a kick but there was always delay. I’m hoping the tune got rid of that delayI could tell the difference immediately. The FP tune was noticeably stronger and, if anything, has become better over the last month. I'm sorry to hear that some are disappointed.
I also do not have the k&n filter. By chance do you have other mods like exhaust and intake? Give it some time, mine only got better as well as someone mentioned. When you have a chance when it safe and no one around, maybe try a WOT from a stop on S, traction control off. You’ll feel it then for sure.I’ve been using 93 the last 4 fill ups. But I do Have to be honest tho. I did Not install the kN filter. I doubt that’s the problem. I read In other forms like the mustang forms that currently it need sometime to adjust. Idk how true. I’ll give it some time tho. The transmission does feel different in d. It doesn’t lug as much on hills. Which I normally Drop down to S.
That delay is turbo lag, if you slam it all the way down fast it will have that. If you want to avoid turbo lag, push down 30-50% then ease down firm the rest of the pedal travel. The truck is definitely smoother and linear and stronger throttle response. But will still have turbo lag if you pedal to the metal fast.Don’t be sorry. This isn’t my first tune per say. I’m sure it’s faster. I think The power is linear and smoother. Before I felt More of a kick but there was always delay. I’m hoping the tune got rid of that delay
Yeah, I too felt the difference, both in S and in D, right away. It is not huge, but it is significant and, in my opinion, worth the money. I did not get any measurements to back this up, just my butt dyno talking!Interesting. I immediately felt the difference, do you drive it spirited though? I drive it on S mode exclusively. I went from a 7 second 0-60 to 6 second after adding FP tune, roush cai and borla exhaust at same time. If you drive it on D and not spirited, it could feel pretty much the same. Open up that throttle on S after the CHT is 190+ generally closer to 195+. Something to also note is perhaps your truck isn't used to 91 yet, I ran 91 the second I had it, put 500 miles on and then got the relative tune and mods.
Yeah, I figured it was turbo lag and it needs to build up boost. But I always Thought the turbo was small and that cuts down the lag. But it’s my first truck and I have Remember it’s heavy lolThat delay is turbo lag, if you slam it all the way down fast it will have that. If you want to avoid turbo lag, push down 30-50% then ease down firm the rest of the pedal travel. The truck is definitely smoother and linear and stronger throttle response. But will still have turbo lag if you pedal to the metal fast.
That, alone, is worth the upgrade! Tuning is a weird topic. If you aren't driving 'balls to the wall' all the time, then you might not realize what is going on. Less power dips in acceleration, broader torque curve, and drivability are all things improved with a tune. I don't have the FP tune (or any tune) but the FP is on my list. I need to keep the factory warranty.MPG is better.
