MountainGoat
Great thank you.Tow hitch accessory is the correct one. There are only 2 different OEM bumpers; one with the receiver/hitch and one without. Doesn't matter which trim/package you may have.
For wiring, I used the OEM 7/4 pin connector and the wiring harness to connect it. Part numbers were:
FU5Z-14489-A is the connector sleeve/7 and 4 pin connector
KB3Z-15K868-D is the wiring harness (remove existing wiring harness/4 pin plug and replace with the new harness).
Note: There are different wiring harnesses based on the presence of reverse sensors in the bumper. The part number I used did have the connections for the reverse sensors, as I had them in the bumper and needed them in the harness for my install.
When I went to install the bumper step, the instructions showed 3 bolts underneath the bumper. Mine only had 2 and using them put the step inside the bumper making it useless.I ordered the same for my 2019. install was a bit of a pain, took about 2 HRS. I don't know how much different the Sport is.
