I'm about to cut the wires on my factory backup camera...
OFC Ranger
OFC Ranger
Jack
ZR2
Plug and play from Rostra , if you dont want to snippy snip...
The harness for our Ranger is only 5 pin behind rear emblem.
Also, why pay when I have the tools and material to make my own harness. ;)
Dahveed
Central Kansas
Pharmacy Consultant
It plugs in to the connection behind the bumper. Where you disconnect it if you need to remove the tailgate.
OFC Ranger
OFC Ranger
Jack
ZR2
Pro tip, thats just a bigger harness that ties in with the rear power gate lock wiring.
The camera is 5 wires. Easy snip snip to add in extension I need.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
I figured it might be, and looking at your picture I see that it is. There's a set of twisted pair wires there. You'll want to make sure you use a similar setup on your extension wire. Those will be the data/signal wire from the camera. They're done like that to reduce noise in the circuit.
OFC Ranger
OFC Ranger
Jack
ZR2
[/Q
Here or there. I don't care if the guide lines are out of wack, never use them anyhow. Ill rig up an angled bracket.
