I need to remove this panel to do an install. Please let me know how it is removed. I have pulled on it, but don't want to break it. Thank you everyo.
RangerBill
Floor Console
Removal
NOTE:
Removal steps in this procedure may contain installation details.
  1. Release the retainers and remove the lower RH center stack trim panel.
    Use the General Equipment: Interior Trim Remover
2.
Release the retainers and remove the lower LH center stack trim panel.
3.
Remove the bolts and the lower center stack trim panel.
  • Disconnect the electrical connectors.
    Torque : 17 lb.in (1.9 Nm)
1pt21gw
West Coast
Ye' Ole Traveler
Better question, whatcha putin' in?
But yep, easy peasy.
Either buy new sides, or get more white clips, cause somwthing is gonna break.
Toonie sitting in the cubby - such a Canadian. ?
Try this video also - you might have to use trim removal tools to take the panels beside it off.
Good luck!
ColinC
ColinC
Colin
Ontario Canada
2021 Ranger Tremor
BMW technician
Floor Console
Removal
NOTE:
2.
3.
Damn! Thank you so much! This is very helpful.
Floor Console
Removal
NOTE:
2.
3.
That's it. One thing of note. For the left and right trim panels pull them straight to the back of truck and slightly out. If you go out the side you WILL break tabs.
OFC Ranger
Jack
ZR2
As others indicated you can't pop it out as it is held in by bolts.
I know for me and a lot of others was perfect spot for a small form factory radio; in my case a 25W GMRS
Glocker
Boca Raton
I highly suggest going to Harbor Freight/ordering from Amazon a set of trim removal tools. They are inexpensive and will save you from butchering your trim panels.
Something like this:
LivTee 5 pcs Auto Trim Removal Tool Kit, No Scratch Plastic Pry Tool Kit - Interior Door Panel Clip Fastener Removal Set for Vehicle Dash Radio Audio Installer (Blue) https://a.co/d/9tudcRH
This is what I installed...
ColinC
ColinC
Colin
Ontario Canada
2021 Ranger Tremor
BMW technician
Thanks for that info. I do have a set of trim tools. I'm actually a tech, just not a ford one, so it's easy to break trim when you don't know lol.
leanit
Matt
Redwoods
2022 Ranger Lariat FX4
I totally need one of those fascia panels. They've stopped selling to the USA. Dammit.
