Humming noise from engine
Vellucci
Ricky
Melbourne
Ranger wildtrak
Plumber
Hey guys was wondering if anyone could help
My 2019 wildtrak has this wired humming noise coming from the engine. It mainly happens when releasing my foot off the gas and when it changers gears. The other day I toped up the coolant reservoir and the noise went away for a short time until it built up pressure again. I got home and waiting for the car to cool down and opened the cap again to let the pressure out took it for a drive and if was fine, again until pressure built back up? Does anyone have an idea what this could be?
cheers
cheers
Hi Ricky,
Since we do not have a diesel here in the North American market, It is hard to help much. It sounds like you might have a defective radiator cap that is venting and making the sound..cheap part to replace and see if it remedies the problem. JMO.....
Vellucci
Ricky
Melbourne
Ranger wildtrak
Plumber
Hi Ricky,
Thanks for your reply Phil I will replace it today to see if it solves the problem
Cheers
Nicko
Nick
Melbourne Australia
2019 px3 ford Ranger
concreter
Hi Ricki. Did you find out what was causing that humming noise in your engine as I have the same problem and it’s driving me nuts trying to work out what it is. Any info would be much appreciated. Cheers Nick.
Motorpsychology
Prescott, WI
Vagabond
This thread is over two years old, so Ricky probably took Phil's advice and bought a new radiator cap or learned to sing along with the humm.
Seriously, the vacuum valve inside the cap may be fatigued and vibrating., causing a hum. ?
Wondering.....
Did it sound like Hummmmmmmmm
or, HumHumHumHum....
or, HumaHumaHumaHUma...
or YumaYumaYuma ?
I was wondering what the tune was?
