How to remove rear trim panel behind rear seat
mark_anderson_us
Chicago
Ford Ranger Lariat FX4 2020
Software Developer
Hi All
Need to run some wires behind rear seat in my FX4 Lariat (full size cab, also has amp and sub behind seat)
Anyone know what I need to do to remove the rear trim panel
Thanks
mark_anderson_us
Chicago
Software Developer
The trim piece by the seat belt I just pried it back and snaked the wire through it but it does come off easy enough if you need to remove it. All the trim pieces just pop out of place, some might need a little more force than others but they do come out. I only needed to go to that point so I'm not sure what else you're going to need to take apart but it should be very easy.
TechnicallyReal
Ryan
Eh?
'19 Ranger Lariat 4x4
Software Engineer / IT Admin
JACKSMYDOG
Jay
Ontario
2020 Ranger Lariat FX4 Black
I bought a set of these from Amazon. I used the to install my dash camera and they worked out great.
The lower piece of the rear trim just pops straight off. GENTLY pull toward the passenger side, using a plastic tool at the point of resistance if needed, but I pulled mine last week with no tools.
IIRC you'll need to remove the top door sil guard trim piece too. Again, pick an edge, lift gently.
The door sill guard comes off really easy and I'm glad I didn't crack mine because I pulled on it kind of hard.
I was able to snake the dash camera front to rear wire through the seat belt plastic without having to take it completely apart but the top edges pulled out really easy.
JACKSMYDOG
Jay
Ontario
Yes sir, I didn't mean to reply to your quote, just stealing the photo ;)
Trim pieces can be tricky. Most are just a straight pull, in the right place, but gentle. The cracking noise, normally means it was the wrong direction, lol.
I try to not pull on the trim pieces with to much force because I've broke my share. I thought the door sill was on there tighter than it was but it came off easier than expected. Yeah that cracking noise usually means it just cost you more money to buy a new panel. lol
FoD
Terry
Out There
Retired & Grandparenting 🤣
Here's from Service Manual on back panel, do you need to remove the C pillar also?
It depends on the route you're going with the wires. When I ran the wire that connects the front and rear dash cams together I just used the tools to pry around the edges of the A & B pillar and it tucked right in nice and clean. I then came down the B pillar and under the door sill protector and across where the two back panel pieces split.
FoD
Terry
Out There
Here's C Pillar
Good luck!!
FoD
Terry
Out There
And I have run wiring from the amp area under the carpet, under the storage area and under carpet again to center console and up to dash. Just all depends on where/what you are connecting up.
Could always just throw the wire over the drivers seat and tape it to headliner (or staple) :crazy:
Why to the center console? You can run the wire from the fusebox under the drivers door sill protector and then under the carpet to the underside of the drivers seat to connect to the battery pack.
Why do I picture yours looking like this? ?
