How To Install Tailgate Damper
TDImark
High Desert of SoCal
2020 Ranger XLT 4x4
It should make a soft gurgling noise. If it’s loud that may be a good question for DeeZee.
Thanks for the info. I watched the install video at the beginning of this thread and on full volume I did hear a very similar noise. I think mine is a little uglier than the soft - and almost pleasant - sound other lift struts make. At least the ones I've heard before. But, hey, it does work.
JimH
Palm Coast, FL
2020 Ford Ranger XLT SuperCrew
I've noticed that when my tailgate is down, the cable on the side with the dampner is slightly loose, not tight like the other one. Seems the dampner needs to be slightly longer. Anybody else have this ??
Deleted member 1634
Mine is actually the opposite. The damper side is taught and the pax side is slack. I think it's just part of the tolerances of the tailgate, attach points, and cables.
Heck mine is like that without the damper.
Oops! cats out now! Better order mine quick.??
lanceriley
Randy
Philippines
Ranger Raptor
Farmer
my pickup came with a tailgate assist. found at the hinge part... do i still need these dampers?
FoD
Terry
Out There
Retired & Grandparenting 🤣
To help with economic recovery, you can pay someone to lower your tailgate for you ( usually by laying in bed of truck until needed). You may need the optional bookend, someone to raise it back up.:),
I think it'll get marketed as the "Tailgate Doorman". :giggle:
This, as an option to the damdamdamper:LOL:
Whiskeybilt
Jamison
Virgin islands
2019 ranger
chef
I hate myself for asking this question, but one of my gripes is how easily the tailgate comes off. Happens accidentally pretty often and I'm terrified of driving with it down. Will these prevent that?
Can I block DZscorpion from seeing this post? lol
Hi Jamison,
What you need is the tailgate lock bracket from McGard, but yes the damper will slow down anyone trying to seal the tailgate but the lock will do a better job. As for being down, the tailgate is pretty rigid. It only pulls loose on the right side at about a 45° angle otherwise up or down it is locked in place. Hope this makes sense..
Tim H.
TJ
Maryland
2020 Ranger Lariat 4X4, 2016 Corvette Stingray
REALTOR
Hi Jamison,
Coincidentally I just finished installing the McGard lock this morning. It was a little wonky holding the tailgate while holding the bracket and placing the hinge back in its socket. I could have used a second person to hold the tailgate. All‘s well that ends well!
DevilDog1775
C
C
Tailgate dampers seem to be a pretty polarizing topic around here, but if you do decide you want one they are really inexpensive and incredibly easy to install. Just make sure you have a Torx T50 driver on hand to do the job. Here's a short video I made demonstrating how to install the DZ43206 from DeeZee (which is the exact same part Ford will sell you at a markup if you order the kit from them):
Great video. However, you left out the part where you first light the candles and ask for the guidance and gift from the Damper God to grace your tailgate with gravity defying abilities. :) Happy Monday!
Not a chance! When it comes to tailgate damper posts I see everything. ?
I've never had the tailgate try and come loose before adding the damper. Adding one will keep it in place and it shouldn't come off. Now you'll have to break down and buy one just for this reason alone. ?
