Hood alignment
Craig
Craig
SLC
Seems to me that temperature has a lot to do with hood alignment as if the fenders and hood were made of different materials. Just a thought, get back to me after looking at them at different times of the day
Stevie Gee
Front fenders, hood, and tailgate are all aluminum.
Hounddog409
Tod
Ohio
F150
Both hood and fenders are aluminum....but it was a good thought.
Cape Cruiser
Bret
Southern Delaware
retired mechanic
It didn’t matter what time of day, or what the temperature was, the fenders had to be pulled out.
Thanks Ric I did mine also, it was the same as yours
joeb427
Cape Cruiser
Bret
Southern Delaware
retired mechanic
My driver's side is off a bit. How did you move the fender out?
Pop the hood and you will see 3 10 mm bolts on top of the fender. Loosen the bolts and lightly pull out fender and tighten bolts. My rearward bolt was maxed out in its hole and the fender is slightly still off but only about a 1/16,I could open up the hole but for now its much better.
Ric
Ric
San Bernardino, CA
Honda Accord
The hood over hang was on both sides. The driver’s side was 1/4 inch off and the passenger’s side was 1/8 inch off. The fender bolt holes had to be enlarged. A dremel was used. The picture is after the passenger’s side was moved. The driver’s side was moved out even further.
SubVet
Myrtle Beach
Just pulled my fenders. Also readjusted the hood latch a bit lower lessen the gap on the hood at both sides. Had to remove the plastic trim piece at the front of the engine over the grill to adjust the hood latch down about 1/2" to eliminate the wider gap on both sides of the hood toward the front.
Craig
Craig
Craig
SLC
Thank you, that what I wanted some feed back. Thanks for the pictures, good to have when I go to the dealer
VAMike
2019 Ranger Lariat SuperCab
also consider that if the hood or fenders were expanding/contracting that much, the paint would fall off
