dtech
Well if you mostly do shorter trips the mpg probably isn't much a concern, I did over 1200 miles on my recent trip which was 6 days in duration, cut it short by 2 days owing to sub freezing temps , 5 days spent with full hookups but last 2 would have been boondocking so relying on propane to keep warm. If I ever do a 6 day trip again covering 1200 miles I'd likely book lodging and leave the TT behind, just ate up too much gas to make sense.Usually see 10-12mpg depending on which campground we go to here in Michigan. Mostly flat but some hills hence the difference. Always use tow/haul and 60-65mph. Don’t pull much in cold weather so no input regarding that. One campground in particular is 27 miles from home and flat. If I take the back roads (55mph max) then I will see 13mpg.
