Help with hitch
CB750F
Qc
Human
Hi, I have the tow pkg.
I just bought a Curt 4" drop hitch but maybe I bought the wrong one, should have been the 2" drop?
I'm going to tow a Uhaul trailer, which hitch should be required?
Tks.
Bob902
St. Louis
RETIRED!!!!
Tks.
I pulled a Uhaul last summer with a 2" drop.
CB750F
CB750F
Qc
Human
just took a pic, looks good to me..
Danager
Dan
Alberta
2019 Edge
Manager
Call Uhaul and ask them the hitch height when the trailer is level. Then measure from the ground to your receiver. The difference in the two is the drop (or rise) you will need.
paval3
Val
Pennsylvania
2021 Ranger XLT Crewcab & 2003 Mountaineer Premier
I think you will be fine with that. I can't remember if I got the 4 or 6 inch, but which ever it is it is perfect with my aluminum utility trailer. Two inch would never have worked.
When you hook up the trailer to the truck, the "nose" of the trailer should be down a bit...not level, and not front end higher than the hitch.
To be honest, the Ranger's rear is high enough that even thou a 2 inch drop might be whats called for, a 4 inch will probably do just fine.
jsphlynch
2019 Ford Ranger XL
Your best bet is to measure it. Uhaul says that "optimal" height from ground to the middle of the ball is 18 1/2 to 18 3/4 inches.
I'm pretty sure I used a 4-inch drop to tow a Uhaul trailer a few times. However, even if I had used a 2-inch drop, I have an aftermarket receiver that sits a bit lower than the factory receiver, so your hitch would ride slightly higher than mine anyway and thus optimally use a little bit more drop.
CB750F
CB750F
Qc
Human
Thank you gentlemen, Uhaul says it's about 18" & I just measured at about 19" so all good, I guess.
If Bob902 was good with 2" drop a 4" should be fine, 2" ball too, need to go buy that later today...
NTXTremor
Dallas
2021 Ranger Tremor
IT
Looks like you got your answer, but I will add that I think you will be just fine. I recently towed the same trailer over 300 miles with my Tremor. The U-Haul location that inspected my trailer setup suggested the 2 inch drop hitch. Frankly I think it was not enough for the Tremor, but your truck should be one inch lower than the Tremor.
For reference, here is how the truck looked with the trailer loaded. I will probably buy a 4" drop hitch for future towing needs.
CB750F
CB750F
Qc
Human
So, all good, a 2" would have been too high, I'm glad I went with 4".
I'll post a pic later.
Also, got a open trailer. Did 16mpg. With 87, oups.....
