Ronbo
- First Name
- Ron
- Joined
- Aug 10, 2019
- Threads
- 14
- Messages
- 641
- Reaction score
- 3,326
- Location
- FL, CT, TX
- Vehicle(s)
- 2019 Ford Ranger XLT FX4+
- Occupation
- Retired LEO Sgt., USAF & USA Veteran.
- Vehicle Showcase
- 1
- Thread starter
- #1
So, can someone help me understand these tire ratings?
I have, what appear to be, "P" tires on my FX4, that came from factory. I see that lots of people are trading up to an LT tire, which I guess is supposed to provide more plys which makes the tires sturdier and less prone to puncture or have a blow out? (Am on the right page so far?) So I am looking at the LT version of the very tire that I have now, the H/K AT-M's, in the same size, etc, Tread pattern, side lugs, etc, are all identical. I see that the even though the LT tire has a "C" load rating, it appears to be about 200 lbs less load capable than the load rating of the "SL" Standard Load tire. 2469 pounds on P "SL" tire, and only 2270 pounds on the LT "C" tire. Plus the LT tire is about 7 pounds heavier per tire (which affects MPG's). It would seem to me that solely based on the maximum load rating, the P tire would be better, no? What am I not understanding?
Dynapro ATM 265/65R17 Tire Specs
| Size | Diameter | Width | Rim Range | Measured Rim | Tread Depth | Load Range | Max Load | Max psi | Max Speed | Weight | Sidewall Letters | Revs/Mile | ||
| 265/65R17 112T SL OWL | 30.6" | 10.5" | 7.5-9.5" | 8" | 13/32" | Standard Load | 2469 lbs | 51 psi | 118 mph | 37 lbs | Black/White Option? | 679 | ||
| LT265/65R17 109T C OWL | 31" | 10.6" | 7.5-9.5" | 8" | 13/32" | C - 6 ply | 2270 lbs | 50 psi | 118 mph | 44 lbs | Black/White Option? | 675 |
